Question about Uniden UDC7M Digital Camera
SD cards - Sandisk
2GB SanDisk SD card, bought from local PC market worked well, however the camera a Uniden UDC-7M 'locked up' in an unrequested format of the card a week later. To fix one had to select 'Yes' and format the card to get any functionality back to the camera. This lock out (except for format) happened to my wife at a wedding, needless to say my ears needed repairs when she returned. When I checked the camera it tuned on OK but .... the camera wanted to format the card and nothing else would work except off or format. And NO it wouldn't return to Menu. The retailer (a national one)suggested a Kingston Card of 1GB not the recommended SanDisk. For the last few days nothing I did with either card has caused the returned of the problem. I'm not confident that I have really fixed anything! This may come back at a really bad time!!!
  • dndsliladora Jan 30, 2009
    I HAVE A VIVITAR 3785 THAT I PUT A NEW SD CARD IN AND THE CAMERA SAYS SD IS FULL, I WAS TOLD BY THE SD MANUFACTURER TO REFORMAT THE SD, I DON'T KNOW HOW TO DO THAT, PLEASE HELP. KIND REGARDS DONNA
Do you think maybe the problem is with the memory card rather than the camera. It is always safest to format the cards for the specific camera you will be using it for the first time you use it, that way it does not require to be reformated more than once a year ....after you make sure that you have backed up all your photos first ! Next time pack a spare card, but the camera promises to be very dependable.
Posted on Oct 25, 2007
SOURCE:
Sandisk SD card 2 gb still locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 23, 2013 | SanDisk 2gb Micro Sd Trans Flash Memory...
SD reads Memory error locked in camera and computer will not recognize SD chip. Other SD memory chips are recognized by computer. Have moved lock switch up and down and is not in locked position.
Is it a newer 4GB or larger SDHC card, and are you trying to use it in an older (4 years or older) camera? If so, that's your problem. SDHC format only came out a few years back, and older cameras can not recognize them. You'd need to use 2GB or less standard SD cards only. Fortunately, these are very inexpensive these days, and widely available on Amazon if your local stores no longer carry them.
Sep 21, 2011 | SanDisk 2GB microSD Memory Card
I just bought a new sandisk 4GB card for my p880 kodak. Wnen inserted the new card camera screen says card is unusable, insert new card. I have followed instructions for formatting on my PC, but still get...
The P880 works with MMC and SD cards. Your new 4GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The camera is limited to working with cards 2GB and smaller.
Sep 01, 2011 | Kodak EasyShare Z710 Digital Camera
Have a Kodak EasyShare C743, bought a SanDisk, won't format
Your camera was designed before the SDHC format came out. Sorry, your camera can only use standard SD cards, those usually 2GB or less. An SDHC card will not be recognized properly by your camera. If you really want to use a 4GB card, do a Google search for SD and "non hc", with the non hc in quotes. Believe that Transcend makes one.
Apr 24, 2010 | Cameras
I need to unlock a Sandisk SD card, I've just
If you've already tried the slide switch, see this link for additional things that you can try.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
Formatted a 2GB sandisk card in my camera. Lost
If you have an sd slot in your computer you can plug the card into sd slot start/computer/right click removable hard drive disk for sd card format
Mar 01, 2010 | SanDisk 2GB microSD Memory Card
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
My argus cintar DC5315 will not work with a 2GB SanDisk SD card
Due to the devices age (i have one too, i bought it Christmas 2005) its internal parts are not as strong as newer cameras, and therefore, cannot support as much memory as new cameras. I have an 8gb SD card and the camera does not even turn on with that much space, but with 128MB it works just fine.
Dec 30, 2008 | Argus DC3515 Digital Camera
Undoing Delete all.
Download from www.konvar.com the program PC Inspector. Install it. connnect camera or put card into reader. dierect PC inspector to the camera/file and run it. It will recover all files that have not been over written.
Jul 13, 2007 | Uniden UDC7M Digital Camera
Uniden UDC7M Digital Camera Logo
115 people viewed this question
Top Uniden Cameras Experts
Marvin
Marvin
JP Meneide
JP Meneide
Tom Chichester
Are you an Uniden Camera Expert? Answer questions, earn points and help others
