I have a v cast LG Verizon cell phone and my display screen has the words "car kit" on it. I can't make out going calls nor can I get incoming calls. How do I get it off?
-   Same problem - Tried the compressed air on the battery prongs and the plug-in prongs. Still saying "Car Kit" :(-   kkm3
Aug 11, 2008
-   My VX8300 was stuck in "Car Kit" mode. I read the solutions here and I can't believe it, the solution by blowing compressed air into the charging connection worked!!!!!!!!! Thanks,-   Guest
Jun 19, 2008
-   had the same issue, unable to find anything in directions or on phone, may have gotten literally a drop of water on the charger connector. Plugged phone into wall charger and car kit message went away. woo hoo-   Guest
May 06, 2008
-   I just read how another guy said to turn off the phone and use something to touch the little prongs on the bottom of the phone ( where you would plug in the charger). I used a small pair of scissors and much to my amazement.....it worked. When I turned my phone on, it started back- good as new.... and Verizon said it couldn't be fixed. Ha! hope this also helps someone else. Good luck!
It's actually something wrong with your phone. The connector on the bottom of the phone may have gotten wet. If you are comfortable taking the phone apart you can clean the connector w/ 99.5% isopropyl alcohol and a soft bristled brush. Good luck.
What I did was to take the car charger and plug and unplug from phone. This cleaned the bottom contacts and the phone no longer has the car kit on screen and works well again.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jan 31, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I can't believe it...Tin foil worked for me too! THANK YOU!
well i had the same exacts problem because i couldn't hear other people on the other end or any noise with my phone so my dad went and got a can of contact cleaner or that spary that sparays air and where the charger goes in I sparyed it there and put my charger in a few times and when i opened it the car kit was GONE!! I reccommend contact cleaner!!
Which is the best Cell Phone having the feature of 3G in brand Nokia within price brand of...
(More)
Which is the best Cell Phone having the feature of 3G in brand Nokia within price brand of Rs.10,000. Thanks in advance, jaypoo
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer...
(More)
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer care service and then they gave it to me, when I put it in it said I had to change my Pin code, so I changed it and now I forgot it.
How do I change it again ?
