Question about RCA F36676ET 36" TV
RCA F36676ET TV problem
My TV just cut out and when I plug it back into the wall it makes a wierd ticking sound but won't come on.
  • 2 more comments
  • ckoomen Dec 04, 2007
    We were just watching it and the sound went out. Now it just ticks right when we turn it on.
  • c_slemko Dec 11, 2007
    I have the same problem with mine, after it's unplugged the ticking continues for a couple more seconds until it fades away.
  • J Ely Jul 07, 2008
    The tv just stopped turning on. I turn it on and it clicks, clicks, clicks. It is a F36676Et 36 " TV. From 1997. I have turned it off until I can get it to turn on again.
  • blondie34633 Jan 09, 2009
    RCA Chassis-PTK195516B. I have the same problem and don't know what to do. Can someone help me?
  • 93 Answers
Its ur horiz. output transistor i just fix mines
Posted on Jan 04, 2008
  • surfsweb Dec 25, 2010
    Could you please give some details about the repair, my RCA 36" Home Theatre Model F36676ET is doing the exact same thing. It was working fine, then one day when I tried to turn it on, I just hear a few quiet beeps / clicks then nothing. No sound, no picture, no green power light. If I try again, it repeats same symptoms.
    Thanks in advance.
SOURCE:
Lg tv ticking
There is some shorted component/s in the circuit board. The short circuit protection circuit detects this short, and shuts down your TV again and again. That is why you hear these 'tick' sounds repeatedly. Contact any experienced service technician to get your TV repaired. The work is skilled one, which need sound knowledge in electronics, and work experience.
Jul 29, 2012 | RCA TruFlat 27F520T 27" TV
Hi my rca p52937 won't turn on and is making a
The ticking sound is almost always caused by the Flyback and Hot transistor. It could be other items also located on the deflection board but flyback is most likliest. You can get a replacement flyback and Hot tarnsistor from www.tvrepairworld.com
Jul 07, 2011 | RCA Televison & Video
My tv wont turn on.It just beebs it even beebs for a second or two after its unpluged..?
sounds like your display has gone check to see if the speakers r makeing any noise and i would sugest takeing it to your local tv repair shop.
Mar 08, 2009 | RCA F36676ET 36" TV
Rca f36676et manual
servicemanuals.net on web.
Dec 09, 2008 | RCA F36676ET 36" TV
I have an RCA F36676ET that has a broken cable connection. TV works fine with DVD player but satellite connection not recognized. Can the cable connection be replaced? Can I do it myself?
If you mean the cable connector is broken off, then yes, that can be replaced. A company called MCM Electronics sells replacement connectors, but the repair requires soldering skills. Incorrectly done, the repair attempt can create even more problems. I suspect your satellite receiver has A/V outputs like the DVD player. Why not connect the receiver the same way as the DVD player and forget about the cable connection? You'll get improved picture and sound that way. If the set has only a single set of A/V inputs, you can cheat and use "Y-adapters" available at Radio Shack to connect the two sources to the same jacks, or you can get an A/V switch to do it.
Dec 03, 2008 | RCA F36676ET 36" TV
Part #H Q401 1511936A
A common cause is a failure in the horizontal output stage. I have had a defective flyback transformer cause this.
Also, when the flyback fails it sometimes takes out the horizontal output transistor and some other parts with it. It is possible that the power supply has some damage from the failure.
Jerry G.
Apr 19, 2008 | RCA F36676ET 36" TV
Tv will not come on
Bad flyback transformer part # 257807 possible damage to horiz out xistor # 237470...change transformer first,then xistor if you
must.....no generic....OEM quality only........T.
Mar 10, 2008 | RCA 36F530T 36" TV
No Power to Model # P52920BL
Sounds like the flyback transformer and horz output,the output shorts and the set will just tick when its pluged in to the ac
Dec 30, 2007 | RCA P52920BL 52" Rear Projection...
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Televison & Video Logo
213 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
