Question about ASUS M3000Np Notebook
M3000 is the hard drive adapter od the a3000 and the m3000np the same
  • manmurali Aug 12, 2008
    all drivers need
    Sergeant:
  • 457 Answers
Similar yes but depending on what you intend doing?
Posted on Sep 10, 2007
SOURCE:
Rv510 plugged in but no lights on my laptop
You need to check all of these: 1. External charger, 2. Battery, 3. Internal charger, 4. Software. First, check if the battery is fully charge (or more than 80% charged). Second, use a tested good working battery charger/ac adapter to test your ac adapter (go to local electronic stores and test your laptop with their ac adapters). Third (if your ac adapter and your battery are good), then check your Power Options (click Help and search "power option" if you don't know where it is). If the Power Options is ok, then your motherboard (internal charger) has a problem. You need to bring your laptop to trusted local laptop repair shop.
Feb 28, 2014 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
How to connect my canon powershot A3000 to macbook air
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Dec 07, 2012 | Canon PowerShot A3000 IS Digital Camera
Canon np 8530 - does it have a hard drive?
Hello Jo,
There are no NP series Canon copiers (available to the public) that have a hard drive.They are analog devices and were the "proving grounds" for the current IR and ADVANCED series devices Canon makes.
Jul 29, 2011 | Canon NP 6085 Copier
How do i get my sanyo hdp-m3000 to work on windows 7
Hi Gloria788 just plug it in with the supplied usb cable that came with it and use musicfilemaster which you can download from sanyos site for the m3000
Aug 14, 2010 | Sanyo HDP-M3000 MP3 Player
Hello, I formatted the M3000 with Ubuntu Linux, and... i'm stupid
Take your Sanyo back to Linux box, hook up the USB cable, and then mount it.
Copy the files that you want to keep on to the $HOME directory on Linux.
Next, from a terminal, run
sudo fdisk -l
to display all the mounted filesystems on the computer.
It might be /dev/sdb1, or /dev/sdc1 You should be able to pick out the M3000 as its hard disk size is 6.0 GB. Let's assume that the USB drive is on /dev/sdb1
Re-run the fdisk command.
sudo fdisk /dev/sdb
(press m to get the help menu).
Recommend that you choose d to delete a partition,
then n to create a new partition
when asked about the code for the new partition, use b -- this corresponds to Windows 95 FAT32 file system.
Don't forget w to write the new partition definition out to the USB drive.
Lastly q to quit fdisk.
Once you exit fdisk, remount the M3000 and make sure that you copy your files back on to it.
All Linux and Windows systems should be able to recognize your drive now.
Mar 16, 2010 | Sanyo HDP-M3000 MP3 Player
Don't have the M3000 hard drive caddy
you can buy from here:
http://www.alphapcstore.com/asm3pa.html
add: m3000=a3000 HD candy
hope this help you
May 13, 2009 | ASUS M3000N Notebook
Can"t surf the net after i format my laptop
You evidently reformatted your hard drive. I would assume that you then installed Windows.
Did you reinstall all the Lenovo drivers for your computer? Sounds like you probably didn't or you would be able to connect to the internet like you used to do.
So--you need to go to Lenovo's site, download all the drivers for your computer (especially the network adapter) and install them on your laptop.
Apr 24, 2009 | Lenovo 3000 N100 Notebook PC
Maxtor 3200 External Drive
You can buy a universal adapter. It works 99% of the time on all harddisk housings.
Feb 15, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Bluetooth m3000 headset
The official manual in PDF format can be found here: http://www.amazon.com/exec/obidos/tg/detail/-/B0000CEPCR
Jun 19, 2007 | Plantronics M3000 Consumer Headset
ASUS M3000Np Notebook Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
