Question about Motorola Mobility RAZR V3
Screen went blank
My razr was working just fine. Closed phone after a call. Upon opening phone a few minutes later, saw that screen was blank, or white. Phone still dials, can receive calls, etc. Left battery out for an hour and tried again. Same thing, white/blank screen. Any suggestions? Please?
  • Anonymous Jan 10, 2009
    I have the same problem, except my screen went black.
    Any help?
  • Anonymous Mar 26, 2014
    Went to turn on my Samsung GT 19300 and the screen on the phone is blank. I can't see a thing or who's calling or texting me what can I do as I only got it in Dec last year, it was a gift. Please help what can I do?
Had the exact same problem... removed the battery and sim card, the put them back in. Problem fixed!
Posted on Jul 24, 2008
I had to use a Torx 5 screwdriver from my sprint phone but the solution worked. I was amazed. I am not very mechanical at all! Thanks!
Posted on Apr 19, 2008
    New Friend:
  • 53 Answers
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
SOURCE:
My screen just went blank
If u have a Razor (As shown in the picture), If the mini Screen Works(When you close the phone) then then make sure the push down button((Turns off the main screen when you flip the phone closed) is not pushed down while the phone is open.
Hope this helps.
Jul 01, 2009 | Motorola Mobility RAZR V3
Razr Screen is Blank
Try to take the battery out and put it back after 20 minutes later. Issue might be software related too. If software issue re-flashing will resolve the issue.
Good Luck
Jul 09, 2008 | Motorola Mobility RAZR V3
Phone is working but Screen doesn't work its blank
I have a similar issue...left side hinge pin came out...found it in my pocket and attempted to put it in place and then the screen went blank...no luck...but I was able to take the motorola phone toola and retrieve the data, names, etc and move to another motorrola phone I have. A few days later I found a small wire clip thing that must ground or contact something in the hinge...no luck yet fixing it. Help
Oct 12, 2008 | Motorola Mobility RAZR V3
BLANK SCREEN
well you need to try and have the LCD or flexcable replaced.
Mar 31, 2008 | Motorola Mobility RAZR V3
Won't turn off!
the first troubleshooting step suggested would be to remove the battery and put it back after a while and then givin it a try..
Jan 12, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Blank screen
papdaddyz - replace both the LCD and teh flex cable.
bjantnymom - replaced the LCD screen.
Nov 18, 2007 | Motorola Mobility RAZR V3
Razor screen went blank
i tried some electrical contact cleaner (brake cleaner WAL-MART .89 cents) on the hinges. Open ti back and forth several times. NOTE: do not spray alot, just a little at a time. Then it got squeaky and started working. Then I sprayed a little WD-40 on the hinges and it works fine.
Nov 16, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
Phone shuts down when closed...
the phone's firmware needs to be reflash so take it to a mobile service center and have them fix it for you.
Sep 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
220 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
