Question about GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven
Advantium Microwave Problem
I was using the 5 year old Advantium to warm up some chicken and it just stopped. There are no lights on the panel and no light inside. The breaker was not tripped but I did turn it the breaker on and off. I also unplugged it for a couple minutes and it still shows no sign of life. Any ideas on what I could check? Thanks
  • 1 more comment
  • Julietas Jan 04, 2008
    I have the EXACT same issue and have no idea what to do about it. I don't want to call an expensive repair company if it is a simple fix. Have you figured it out?
  • Jeffsok Jan 25, 2008
    I was able to fix it by putting in a new fuse. It is behind the panel on the top left side of the machine. The fuse was about $2 and I found one at an appiance store.
    I meant to say the fuse is behind the panel on the top RIGHT of the machine.
The rotating part that rotates 180 eegrees and then rotates180 degrees in the opposite direction. Many times it rotates but the food on top of it fails to go with it..
Posted on Jan 25, 2008
Fuse
Posted on Dec 07, 2007
SOURCE:
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 | Ovens
Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
GE Advantium stopped working completely...indicates no power but it is on.
It may be that your high voltage diode or capacitor has shorted.
The fuse is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To check the high voltage parts, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Dec 16, 2008 | GE Profile Advantium SCB2001KSS Stainless...
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
Advantium zsc2001fss no power no lights
I have same unit...power outage made unit come back on and it then requested user to set the clock, but the display shows the hours but won't accept the pushputton to lock it in. I had to look at the control panel today to see how hard it would be to replace.
To take off the front vent panel: first take microwave out of the built-in space, disconnecting the power cord. Then the top outer metal skin can be unscrewed and removed, which exposes the screws that hold in the front top vent and the control panel in place.
Feb 21, 2008 | GE ZSC2001FSS Advantium Electric Single...
The GE Profile Advantium SCB2001KSS started beeping and displaying error code F3. I was able to set the time after holding one of the controls in for 3 seconds, but it reverted to the beeping and F3 error...
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Oct 19, 2007 | GE Profile Advantium SCB2001KSS Stainless...
F3 Error
This is due to a Defective control board..You have to get it replaced..
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Unit has no power.
Aug 22, 2007 | GE ZSC2001FSS Advantium Electric Single...
GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven Logo
328 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
