Question about Pioneer TS-W3004SPL Car Subwoofer
Spyder disconnects easily.
I work in car audio as an installer. I've gone thru 4 of these subs. unfortuneatley i'm switching. They don't actually handle the power they say they do continuously. And every single one i've had the spyder disconnects from the cone at around 600 rms.
Wear in period is somewhat of a myth. I'm a full time installer right now. And have been for 2 years. Every sub is broken in if you will and my gain is not cranked b/c any sound if distorted will blow your subs no matter how loud you have it.
Posted on Sep 25, 2007
  • 752 Answers
Are you giving them proper "break-in" time? Also, if you have your gain set too high or especially have the LOUD on or BASS up on your head unit you will get nasty uncontrolled excursion which can tear ANY speaker up.
Posted on Sep 22, 2007
  • Mitch
    Mitch Oct 06, 2007
    i can attest that break-in time is NOT a myth. I have been an installer for 11 years, and am working on a Bachelors in Electrical Engineering and have worked closely with Engineers from companies such as Cerwin-Vega and Paradigm...
    Ayway, speakers ARE tested before they leave the plant, but it's only a 3 or 4 second sweep/warble test. So, the gleus in the spider definitely HAVE NOT had time to break-in. Think of it this way... Take a t-shirt and smear it in glue. Now bend it as fast as you can. It breaks in half, right? Now take a second glued-up shirt and slowly bend it back in forth... it becomes flexible right? Same concept. I've seen it too many times and can vouch for it's effectiveness.
3.1l. How to remove engine
The engine comes out through the bottom
May 18, 2016 | Oldsmobile Cutlass Supreme Cars & Trucks
Keys locked in trunk of 2007 eclipse spyder convertible
at trunk button override and jump switch if dont work have to make way to get through at back seat
Aug 05, 2012 | 2007 Mitsubishi Eclipse Spyder GT...
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Mitsubishi Eclipse Spyder 2001 what fuse for the power windows part #
I've been messing with the stereo and took the seats out to check the amp. I don't think I disconnected the negative cable on the battery and now the windows won't do anything and the top won't go up or down. What did I screw up?
Sep 17, 2010 | 2001 Mitsubishi Eclipse Spyder
One sub works other doesn't
Disconnect the wire from the speaker and meter it out. check it for a dead short, the meter would read 1..... You can also check the action of the sub by pushing on the center lightly, moving the cone. If it's blown, it will not travel smoothly. If your meter reads ......1 then you've really done it and totally cooked the wire clean thru, thus no resistance. Hope this helps.
Sep 29, 2009 | Xtant A3001 Car Audio Amplifier
Kicker zx850.2 and two kicker s10l72
http://kicker.com/dvc_wiring , check this out. for that set up i would recommend either getting a mono amplifier or dual 4 ohm subs. hope that helps.
Sep 24, 2007 | Kicker ZX850.2 2-Channel Amp - 590W ZX...
No sound to speakers
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
Jul 01, 2007 | Hifonics BX1500D Car Audio Amplifier
Constant switch between ON/OFF/source
Does the menu controls work on front panel?If so you can try factory reset or Recall as it is called on some monitors.
Mar 07, 2007 | ViewSonic VX924 19" LCD Monitor
Pioneer TS-W3004SPL Car Subwoofer Logo
79 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
