Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic 51" I just replaced both my convergance amplifiers on my Panasonic. When i powered back up, heard small "pop" and then slight smell of somehting burning. Smell went away, no picture, howerver, I noticed the "Power" indicator continued to flash. Any suggestion?? Thanks Chris
    Problem Solver:
  • 13 Answers
First there are a few questions. Did You disconnect fly back xformer (black honeycomb looking deal with red large gauge wires)? Did you make sure your solder splash didn't bleed over on causing shorted amplfier(s)? Have you identified what component has went home to ma ma? You should see discoloration on either board, replace blown fuse power board replace damage part(s) and go over real good before applying power.
Posted on Sep 07, 2007
51 inch hitatichi rear projection television was watching a program and then it went off and will not turn back picture...sound comes through the theatre
You have bad amplifiers otherwise known as IC's which serves the purpose to give you a true grid for your picture which people know as convergence. If these Ic's are completely gone you will need to replace them before your television will turn back on.
Another problem that you may have is the glass fuse which is located next to the power supply is blown and needs to be replaced.
May 09, 2010 | Hitachi 51F500 51" Rear Projection...
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
Feb 28, 2010 | RCA Televison & Video
Panasonic 51" projection tv, green/purple rainbow across the bottom and the words at top of screen are bent up
Convergence it dead.Convergence ICS and all of it resistors must replaced to solved this problems.Know how to solders?Buy a convergence kit at Tv repair, well cost u $300 for parts and labors.
Jan 19, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Jan 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Lots of red in pics otherwise great
If you have double image sounds like you have a convergence problem which is very common with these units.Part #STK392-110
Jan 12, 2009 | Panasonic PT-51HX40 51" Rear Projection...
I need help, please!
you have just popped your speaker or the speaker has disconnected from the voicecoil or just burned out you might have over loaded it!
Aug 13, 2008 | AudioBahn A8000V 400W x 1 Car Amplifier...
Tv panasonic convergence trouble
please replace the convergence problems to solve convergence problems
Jul 02, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Powers down
this set is known for the deflection and convergence causing the set to shut down ,watch for clues as where to begin, inspect the neck boards also for arcing as well as the flyback trans former,listen for arcing upon shut down.
Nov 16, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT51HX41E Colors are all messed up
You need to change the convergence ic's IC7001,IC7002 = part# STK392-110. Also check for any burnt or discolored resistors nearby. (about a $350 - $500 repair)
Aug 20, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Projection TV wil not cut on.
You should first replace the convergence IC's, both of them. Also make sure all the resistors on the convergence IC's are good and not burnt. That's probably what you smelled burning. Good Luck
Jul 11, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
