Question about Amana SXD524VW Side by Side Refrigerator
My amana scd23vbw
First of all it's a side by side,seems without warning,both fridge and freezer stopped working,the fan constantly run,I never hear the compressor turning on,like it use to,the coils are clean,I found a little ice on the back wall of the freezer and removed same,I reajusted both temp controls,results were the same.What could be the problem?
  • 8 more comments
  • shumatemj Dec 14, 2007
    I have the same problem. Fridge and freezer has just stopped working. Fan sounds like it is running but no cold air.
  • roxwellsmith Jul 12, 2008
    Without warning, the fridge/freezer stopped working. I can hear the fan at the bottom of the fridge working, but the little one that blows into the main fridge does not work. The compressor seems to work because there is ice at the back of the freezer. It seems that the little fan is necessary to move cold air from the freezer section into the main section. I have emptied the fridge and now trying to get access to the circulating fan
  • m5r12ea811 Aug 22, 2008
    the same as the others
  • Anonymous Oct 12, 2008
    My nine-year old Amana SCD23VBW side-by-side refrigerator quit cooling. The outside cooling fan (at the bottom) runs and the compressor feels hot. I removed the bottom panel in the freezer and confirmed that the evaporator is not cold and the evaporator fan motor does not run (probably because the evaporator is not cold). Am I looking at an expensive repair? Should I consider buying a new unit? Your recommendations will be greatly appreciated.
  • mike lively Nov 09, 2008
    yes, I have the same problem, the small fan at the back is running, compressor is hot. at times I here a faint click like a relay is tring to activate something
    yes, small fan at rear constantly running, compressor hot, at times I here a click from a relay or something
    small fan running , compressor hot
    sall fan running, compressor hot , fridge not cold and freezer is inop
  • Anonymous Dec 26, 2008
    help i have same problem fan is running and evaporator seems to be hot
  • mstuertzel Feb 10, 2009
    The frige started to warm. I cleaned alot of dirt from the condenser coils. That usualy would fix it but this time not. The evap and condenser fans are not running now and the evap is icing up. The timer is only 2 years old. Can I have a bad timer again?
  • 725 Answers
First do you have any heat from the compressor ? ( back bottom of the fridge) is the evaporator fan running. let me know and I can help..
Posted on Sep 05, 2007
SOURCE:
Fridge is warm
Adjust the cooling knob inside the fridge according to the outside temperature.
Oct 27, 2012 | Amana ABB1927DE Bottom Freezer...
My freezer seemed to have quit so I cleaned it out made sure the air flow was good and de-iced everything. Now the bottom of the freezer freezes but the top does not nor does the ice maker work. What do...
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
May 07, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Amana Refrigerators
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana evaporative fan intermittent
I would first suspect that the fan motor shaft just has gunk on it keeping it from starting -- clean & lubricate both ends of the motor.
If this doesn't solve the problem, it's the motor start capacitor -- could be inside the motor housing or could be outboard, connected to it via the wiring harness. A capacitor is a lot cheaper than a fan...
Charlie
Aug 31, 2009 | Amana ASD2625KE Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
May 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana SXD524VW Side by Side Refrigerator Logo
454 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
