Question about HP Photosmart R707 Digital Camera
HP R707 Digi Cam...zoom lense not working
So ok there was an accident when my dad dropped my camera when i was tryin to show him a pic, at the time the camera was fine and closed up ok, i went to put it back on within like 10-15 seconds and the zoon lense only came out like half way, now its kinda stuck there wont go in and wont go out, i have tried switchin the camera on but it only stays on for like 20seconds (if even that) then switches off again and it only shows me the HP loading stuff, i cant see the pics that are on it, i cant take new pics and i really need it fixed there is stuff on the camera's own memory that i really want to keep....is there like a manual that i can use to fix it (my man said he would fix it but he is used to working with much bigger equipment and my hands are dainty enough to fix the problem if i knew how) any help that any1 can give me would be greatly appreciated Kind Regards Jeannie
  • Anonymous May 30, 2008
    my hp R707 lense is stuck out and then turns itself off with the lens still out. So it will not turn on. I tryied the reset button by the battery and tried pushing it in and tacking the cover off but did'nt see any way to make the lens go in
  • hakunamat206 May 11, 2010
    hey solution # 2
    i have the same problem with the "flash charging" it has been doing that for months now. i have recharged it but i cant seem to fix it. does anyone know how?
Ours had the same problem - lens extended and out of alignment. Since it's a lens problem and the camera is out of warranty, I figure what the heck? I pushed and prised and it became unstuck. Worst that could have happened was that I scorched the camera permanently, but it was already useless.
Now if I could just fix the "flash charging" problem.
Posted on Feb 03, 2008
I had the same problem. i already had the newest firmware (2.24, from the battery recall) so i just installed it again using the SD card method. The first time I turned it on/off it got stuck for a moment, and now since then I have powered it on and off 30 times and it has not gotten stuck once......
Posted on Nov 15, 2007
I had the same problem - try to wiggle the zoom lense really carefully and the switch it on again. The zoom objective is canted a little bit and the motor is too weak to move the zoom objective. You can also open the camera by removing all 8 screws around the camera and then removing the metal front (Just pull it in the direction of the zoom lens with your fingernails). Then you can access the zoom lens better ... Andy
Posted on Sep 19, 2007
My HP R707 says the card is unreadable. When the red screen shows up to reformat the card, press OK, it does not allow me to do so. What is going on?
Firstly Sorry for my bad English. I was the same problem. I try a lots of thinks. Then I only push the card in to the camera and hold it there (in it) while I'm pressing the card I command to format it. It's ok. It can format it.But It's my hp r707's problem maybe its not usefull for you.
trueagle
Jul 09, 2011 | HP Photosmart R707 Digital Camera
Tip
What to do when your super zoom camera lens retracted due to a shock or accident
The Super Zooms have very long stratched lense which is very easy to get damaged. If any ways you have a retrected lense due to an accident and have following symptoms I have a solution ( 80% working. I tried on my own camera and it worked. Nikon P80)
1) Your lens is retrected and is not coming out 2) Camera is working but shows lens locked or similar error 3) you can hear the lens motor moving or vibrations from the camera is evident
What you will need...
Claim your warranty first ;) Try this only when you do not have any other options.
You will need something to pull the lens out like a UV filter which connects on the lens' open edge.
Gently pull the lens out thread by thread and keep trying to move lens out by zoom button.
Do it very very slowly and precisely.
Once lens comes out pull out the battery and insert again.If you are fortunate enough your lens will start functioning.
on Oct 05, 2010 | Cameras
Where is the reset on hp r707 digital camera
There is no reset button on this camera. For reseting it follow these steps (from the MANUAL, page 122):
1 In the Setup Menu , select Reset Settings....
2 In the Reset All Settings? sub-menu, highlight one of these
two choices:
? Cancel ? Exits the menu without resetting any of the
settings.
? Yes ? Resets all camera settings to their default value in
the Capture Menu and Setup Menu (except Date & Time,
Language, TV Configuration, and USB Configuration).
3 Press Menu/OK to reset settings and return to the Setup Menu.
Apr 07, 2010 | HP Photosmart R707 Digital Camera
Menu OK button and zoom controls are not working.
Remove the battery and press the reset switch for about 5 seconds. Reinsert the battery.
Jan 28, 2010 | HP Photosmart R707 Digital Camera
HP R707 wont take pictures - get F2.8 1/60 message
Does it work while connected to charger? If yes, you need a new battery.
Feb 04, 2009 | HP Photosmart R707 Digital Camera
R707 Fails diagnostic test 10 (strobe)
I found my answer to this on another board. Remove the battery and SD card. Use a paperclip to press in the small siver dot above the + sign for about 10 seconds. This resets the firmware.  It worked for me, hopefully it will work for you too.
Jul 13, 2008 | HP Photosmart R707 Digital Camera
HP R707 camera
My HP R707 5.1 camera lens is stuckout and will not go back in or out when powered on. It only makes a beep sound and turns off automatically
Jun 20, 2008 | HP Photosmart R707 Digital Camera
'Turn camera off and turn back on' message
TRY DROPPING THE CAMERA -- YOU HAVE NOTHING TO LOSE!
I was heartbroken to learn that my Lumix DMC-TZ1, which I purchased 2-3 years ago, had died -- right during my daughter's dance recital, for seemingly no reason. Tonight I was surfing the web researching replacement cameras (many brands), and I realize that I feel like there is no real "history" on the camera that's any worse than any other camera on the market, including the Canon Powershots, which are all the rage right now. So I started researching on the Fixit site other cameras for possible problems.
What I found is that all the cameras have funky messages (Sony and Canon included!) that result when he camera has been dropped or the lense has somehow been altered. So I read all the different "solutions" and then came up with my own:
I decided that the lense needed to be un-jammed. At this point, if the camera was useless to me, I might as well take a chance and try to unjam it. So I did!
I held the camera about 3-4 inches from a table top. Then I simulated a "drop" (without the case) that was gentle enough that it wouldn't smash the LCD but that would maybe make the lense unjam. (Note: I couldn't SEE any problem with the lense; this was just a hypothesis I couldn't go wrong trying.)
Each time I put the camera on, tried to modify the zoom (a function which normally makes me get the error message forcing me to turn the camera off), and then got the message. BUT the 3rd or 4th time: TA DAH! NO MESSAGE! INSTEAD, A SHOCKER: I WAS ABLE TO MODIFY THE ZOOM! AND THEN I TOOK A PICTURE! AND VIDEO!!!!
So my camera is back! And I also have discovered that the flash problem I had started to have previously has now seemed to have gone away also.
My advice is to just TRY! You have nothing to lose: try "dropping it" back into shape! I know it sounds crazy -- but I just saved at least $200 by doing this!
Mama Maria in Burke VA
Sep 17, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
HP Photosmart R707 Digital Camera Logo
252 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
