Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero 550 water leak and freezing
I am getting an ice buildup behind the vegetable and fruit draws with water leakage running out above the bottom freezer door. Behind the produce draws, on the back of the refrig. are 2 angled down tracks meant to catch water and direct it to a small ribbed plastic tube that seems to extend to the floor pan. Recently after chipping away the ice in the refrig, I noticed that that tube was frozen solid. I poured hot water throught it until it was opened and I didn't have the problem for a few days. Then the situation reoccured. Obviously, the water is condensing in the track and because the tube is frozen the water is overflowing and freezing. Doors seal fine. Can you help?
  • 4 more comments
  • Anonymous Nov 24, 2007
    Have water in bottom of fridge. Hve repeatedly snaked and flushed drain. Lasts about two weeks. Worst aplliance I have ever owned!!! (Came with house) Repairman said drain heater was not the answer.
  • lesfcamp Dec 02, 2007
    I have the same problem with the ice build up. I have spent a ton of money on this unit. 550 model. My unit is 10 years old. I have bought a new coil, new dial to adjust the temp. Also installed this heater for the bottom part of fridge. I still have ice build up. Any help would be appreciated.
  • Anonymous Dec 10, 2007
    I have the same trouble with drain freeze up. I thaw periodically with a hair dryer, etc. It's a project. Seems if fridge temp is lower, there's more time between "hair dryer" remedy. (model 550) I'll look for the tube heater...
  • joyceking Dec 12, 2007
    I have the identical problem. About a year ago I had the drain tube completely replaced and the problem recurred immediately. I have to add that the bottom of my refrigerator is extremely cold. I have to line my fruit and veggie drawers with insulation to keep the items inside from freezing (some still do) while the top of the refrigerator, where I keep my milk, is at about 45 to 50 degrees. I can't raise the temperture setting otherwise everything near the top of the unit will spoil. I think the problem is that there is too little air circulation inside so all the cold air settles to the bottom and freezes the drain pipe. Adding a drain heater might fix part of the problem not the high temperatures at the top.
  • bww1977 Apr 20, 2009
    I have the same problem, didn't have it for the first 8 years. Ran the copper wire and it took awhile, but a year later the ice is massive and tube frozen. Not sure how logn it has been building up. No gunkin the tube. Has anyone replaced the evaporator? Could this be a problem?
  • Anonymous Mar 22, 2014
    WATER COLLECTING ON FLOOR. I DON'T SEE A DRIP PAN UNDERNEATH FRIDGE. CONDENSATION TUBE IS NOT CLOGGED. IS DRIP PAN FOR SUB-ZERO ON TOP OF UNIT?
    New Friend:
Omg I have this problem too...continually thawing the drain tube and I was going to replace the heat tube..rust too where is pours over the vegetable drawer-
Posted on Aug 30, 2014
    New Friend:
Same problem. had a coil installed about a year ago and it worked for a while. now, the problem is back :0 I guess I will have to put a reminder on the calendar to use a hair dryer every couple of weeks and NOT put veggies in the veggie drawer. Maybe Juice boxes?
Posted on Jan 21, 2011
I think the tube is clogged with gunk.  Had the same problem and it recurs every 2-3 years.  Blow the tube out with compressed air. from inside the refrigerator at the drain port.  Insert the air compressor wand in the port and blow in the compressed air.
Posted on Oct 28, 2007
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Posted on Sep 11, 2007
SOURCE:
What causes ice buildup behind the vegetable bin? The drain tube is open but freezes shut.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Sub-Zero 650 / O Bottom Freezer...
My 550 ices up behind crisper draws causing condensate tube to freeze solid
suonds like the tube is stoped up try to un stop it by small thin flexable wire or blow it out with air.hope that helps
Feb 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much...
your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Jan 26, 2009 | Sub-Zero 650 / O Bottom Freezer...
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,449 people viewed this question
Top Sub-Zero Refrigerators Experts
Steve Allison
Steve Allison
louis_benton
Level 1 Expert
john h
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
