Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Same problem as the others, when i come to turn it on it pops asif to switch on then nothing, apart from 16 blinks, what does 16 mean!? How do i fix this?! cheers!
    New Friend:
  • 76 Answers
More than 5 blinks there is a problem in any other section. Maybe in powersupply section, deflection section and audio section also. Sometimes dry contacts in soldered points also give same symptom. Service persons only done this problem. If you technician give the chassis details.
Posted on Sep 06, 2007
Sony FD Trinitron WEGA TV
Main board fault. IIC Bus line has a short. Continious blinks of standby light denotes this. These are called blinking codes.If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. http://electronicshelponline.blogspot.com/
May 05, 2013 | Sony FD Trinitron WEGA KV-30HS420 30" TV
No Picture Stand By Timer Light is blinking
Have to try switching on the the channel through your remote control? Sleep timer maybe On
Mar 01, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
My tv sony wega dont turn on an the standby light blinks 16 times model KV-32FV310
Hello
Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
If it happens even after this process, you just do the following
Press the following button on your remote control as stated
"Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
Just report the result to me through Fixya. Ok.
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My (Sony FD Trinitron WEGA KV-32FQ) is not switching itself on?
I think your control board might be your problem can you get a signal out of the normal composite or coaxial outputs?
Suggest download this service manual first
http://depositfiles.com/files/l51shqooy
Aug 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
    Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
    Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Please post the blink count. The standby light should be blinking a repeated count. That will indicate the circuit where the problem resides.
    Thanks,
    Dan
    May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
    Sony trinitron wega 36 inch
    break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Nov 11, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
    Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
    194 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
