Printer I ran out of colour ink, still have black ink let. Is there a way I can still print without replacing my colour?
  • balunrdale Dec 09, 2007
    ran out of black in and one of the blues. replaced black cartridge, opened printer and selected black only print. Still won't allow me to print, says I must replace the blue. Why can't I just print in black?
I had same problem it wont print with just black even by using the settings.You can trick it into thinking the color cartridge are full by taking out the color cartridge and taping over the clear part of the cartridge were you can see the level of ink.Thats how the machine knows weather or not the ink is full by looking through the glass by either light or some other way and if its blocked it thinks its full.
Posted on Dec 17, 2007
    Novelist:
  • 208 Answers
If its Xerox, it will not allow you to print until the ink is repaced.
Yep, frustrating.
Posted on Dec 10, 2007
  • 3 Answers
Try setting the driver to "Print in black and white". To do this, go to Start Menu -> Printers and faxes. The right click on your printer and select printing preferences. There you should see the "Print in black and white" checkbox. Check that and click OK. All color should print in black. Be sure to turn that back off when you want to print color again.
Posted on Sep 26, 2007
    Scholar:
  • 57 Answers
When you right click or choose print go into "properties" when the window pops up for your commands. In that window choose "preferences" then another window will pop up and in that window choose "print color images in Black and White".
Posted on Sep 12, 2007
  • 64 Answers
Depending on what printer it is. many of the older HP models would just carry on without you having to go into any menus to tell it to just recognise the black ink but now they all seem to want you to have ink in all slots ( basicaly so that you have to go out and buy another set of inks and put more money in their pockets)
Posted on Oct 05, 2007
  • 20 Answers
You should be able to select or de-select on which ink cartridge you want to use. If your running windows go to Start-Printers and faxes, within this window locate your default printer and right click on it then go to properties, now you should see different tabs at the very top. Select the tab for ink or it may say something similar. Their should be check box's for selecting blk\white or even gray scale. Hope this was helpful.
Posted on Sep 05, 2007
4 Suggested Answers
SOURCE:
Silverblade
  • 173 Answers
SOURCE: Black ink not printing and colour ink very faded
Check the ink status of the printer's cartridge.
Posted on Oct 14, 2008
tigertail
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
SOURCE: can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Posted on Aug 10, 2009
My black ink is not printing, I know that I need to replace my color inks.
Some printers won't print unless both cartridges are present.
Find your manual here if you need to.
Good luck
Oct 18, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
Can't scan when out of ink
Unfortunately, there is no way to print with your printer without replacing
the empty cartridges. Sadly, that's just how Epson printers work.
Jan 16, 2010 | Epson Stylus CX5800F All-In-One InkJet...
Brother mfc3360 blank ink doesn't print
brother is good printer,there are many facitil as we can block one type colour as black or colour . look once a time in your printer option.or setting. , Is there on type colour is set only?
Jun 20, 2009 | Brother MFC-3360C All-In-One InkJet...
Do you have to have colour ink when only printing in black
Yes you have to have ink in all of them. No, accordign to Canon it wil not work without them.
Feb 04, 2009 | Canon i80 InkJet Printer
Is there any way to print without using black ink?
All hp printers need both cartridges installed to operate, it can be emty, as long as its installed. Goto prefrences in you printer settings there is a option use colour or black only.... Hope thise solves your problem
Dec 08, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Black doesn't print
I have same problem. Found if I remove and replace the black cartridge before I send a print job it will work. Be interested to know if that works for anyone else.
Oct 17, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
491 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
