Question about Imation (01946) External Floppy Drive
Flash drivers i have alot of information in my flash drivers my problem is got broken when you plug in the computer usb and i would like to know you guy can fix it, i ready call the company they say no they can not fix it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
It depends how it is broken. you might be able to replace the USB connector and have it fixed again.
Posted on Aug 26, 2008
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Dear Sir, When i inserted by Pen drive in my laptop it shows a message " USB Not Recognized" & then i tried the same in various PC's & Laptops but the same message has come. What shall...
Are you getting a "USB device not recognized" error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn't work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn't work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an "Unknown Device".
So how did I finally fix the problem? Well, apparently it's a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
Mar 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Window did not recognized my kingston usb (DT slim)
Usually all flash drive are plug and play devices if your computer is not recognizing it you should try plugging it into another USB port and even try plug in another computer to see if it would work.If your flash drive does not work this mean it is dead and the flash drives are not design to get the information off when it is dead.
Aug 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computer will not recongnize coby player.
What I have seen it is should show up under the flash drives. The one thing you can try is going to the coby website and downloading the driver for the player. That should fix that your computer is not finding your player. Hope this helps.
Sep 28, 2009 | Coby MP-C741 MP3 Player
Where are the free USB driver downloads ? I`m new to computers,but looks like everything that say`s it`s free is`nt.Not if you have to pay a service provider to get it,like driver detective.I`ll even bet...
If you are using Windows go to their website and search driver downloads, and follow from their, if You do have Windows the driver downloads are free I downloded from their myslef...........................
Jun 07, 2009 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
The computer doesn't read the flash drive when i plug it into the USB port
go to my computer property then hardware then device manager then uninstall usb drivers and install again
if u find unknown device u must have to install proper flash drive driver
May 22, 2009 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Tarantula doesn work after installing new firmware
there seems to be alot of firmware issues with alot of razors products at the moment, use another keyboard for the minute and navigate to their site, downgrade your firmware to the one that worked. or alternatively restore your computer to a restore date that occured before you installed the new firmware/drivers.
hope this helps
kev
Nov 30, 2008 | Razer Tarantula RZ03-00070100-R2U1
Problem starting up Maxtor 160 gb external hard drive
hi dutchgirlie,it doent matter if its a trekstor,but my 1st question is did u every try work the usb device?just to make sure it is working.if u havent make sure your usb device is enable in your bios.hope u knw how to do that.hope your harddisk shows up when you boot next time.have a nice time.
raj
May 10, 2008 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Data recovery from a broken usb flash drive ? model dane elec zmate pendrive 512mb
Does the flash drive been detected by computer? If not, you may try other usb port, or other computer and see whether the flash drive is detected. If still not, try to go to device manager and then assign a drive letter to the flash drive. After that, download a flash drive data recovery software, recommended asoftech data recovery, you can refer to this tutorial
How to recover files from usb drive
If still does not work, you may format it (use quick format) and then use asoftech data recovery to recover your files.
Here's a video tutorial I find very useful
May 03, 2008 | Cameras
Imation (01946) External Floppy Drive Logo
79 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
lorenzo carolus
Level 1 Expert
matt
matt
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
