Question about GE Profile JKP18 Electric Single Oven
Oven shuts off when heating
Hello, the oven shuts off when heating. Also melted temperature probe, suspect the oven went over temp then shut down. I cycled the circuit breaker and it acts normal now. The oven temp sensor reads about 1100ohms like the guide says it should. Suspect relay or bad contact. Is there anyway to get the schematic for the control board? Other suggestions? Thanks, Art.
  • 126 Answers
Its easier to replace than fix it i dont know where you would get the schematic GE doesnt have them.
Posted on Dec 14, 2007
SOURCE:
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
Sorry to read about your problem, I hope this helps you out.
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Jan 02, 2011 | GE Profile JTP18 Electric Single Oven
I cannot get the oven to come on after I used the self cleaning.
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
 Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven shutting down
There are also two temperature probes on this oven that will cause the same problem. Let me know what the temp is when shutting down.
Sep 03, 2008 | Lincoln Conveyor Oven - 1133-000-A
Kenmore oven error code f10
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven Temperature Probe
It could be your ignitor, if weak it might not be good enough to draw ampage.I would suggest to change both ignitor and temp probe to be in a safer side. part number for ignitor is 12872 $56.0+, Part # for your oven temp. sensor 833085, it should not be more than $28. other part from www.repairclinic.com.
Jul 25, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 29, 2008 | Magic Chef 9512 Electric Single Oven
GE Profile JKP18 Electric Single Oven Logo
315 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
