Question about Apple iMac G5 Desktop
IMac Monitor I have a monitor issue. On my iMac monitor there is a very thin yellow line on the center of my screen. This thin yellow line always appear on the monitor. Is there a way to get rid of it? Please help. thanks.
  • jmartinezphd Jan 21, 2009
    I used to have a PC. In 2007, I decided to buy a Mac because of the "Equipment prestige and Mac excellent customer service". Nowadays, I am totally disappointed with Mac and all its products. I am more than convinced that I will go back to PC's. My iMac started to show several dead pixels just one day after the one year warranty expired. At that time, I contacted COMPUSA and they wanted to charge me over $900 + service to resolve the problem. A year after (Dec 2009) the right half of my monitor is completely dead...
  • Anonymous Apr 09, 2009
    Half of mionitor i get deepdarker
    It's have i line where it happened
    Problem Solver:
  • 6 Answers
I agreed with Rob.. a ribbon strip missconection can cause a
Total vertical or horizontal cut out dead pix there is a pix controller
normaly a dead pix shows to diferent scenarios
1)Tiny black or Rows black
Tiny is individual Transistors
Row black means video controller lose connection in ALL transistor over all the axix due to ) condition on the grid controller
Posted on Dec 06, 2007
  • 67 Answers
What type of monitor is this? If it is an LCD screen, you may have some dead pixels. Please reply with some more details about your specific monitor.
Posted on Sep 07, 2007
4 Suggested Answers
  • 558 Answers
SOURCE: I have an iMac (version 10.4.11)....and have the
the lcd is bad,for some strange reason this is becoming common with Imacs.I recently repaired about 30 with the same problem.The techs at apple wont say why this is hapening they prefer to replace parts.In your case you will have to replace the lcd display and the cable from the display to the logicboard and not the logicboard.
Good luck
Posted on Sep 17, 2009
Macs R We
  • 481 Answers
SOURCE: thin yellow vertical line
Linear defects of this sort can be caused by a faulty display cable, a faulty LCD panel, or a faulty connector between the two. Much less likely is a problem with your graphic processor, since the line is static in appearance and position. Unless your Mac guy has lots of spare parts hanging around, I would suggest you replace the cable first, as it is the least expensive fix. If that doesn't do the job, then the display panel must be replaced.
Posted on Sep 19, 2009
  • 62 Answers
SOURCE: Smudge, streaks, rays imac 24 monitor clean inside LCD
Yep, you can clean the LCD and the inside of the glass, but you will need two suction cups for glass. The ones for picking up window glass work. Lay the computer on its back. Place the suction cups at the upper corners and pull straight away from the table. The glass is held on by magnets and may have tabs at the bottom, so once the magnets are loose you may have to lift the glass away from the bottom edge. Be careful, it isn't safety glass and can break if dropped. The hardest part is keeping dust from getting between the screen and the glass during reassembly. Try working in a dust-free environment. I use two micro-fiber cloths, one with screen cleaner and one dry. You can't believe how much static builds up on the inside of the glass. It just sucks in dust. Don't wear fleece or you'll end up with fuzz as well. Stand your iMac up to reinstall. Clean the outside of the glass so you can see any dust on the inside. Place the bottom in place first. As you prepare to move the top into place, have light behind and above you and view the glass with the black screen behind. You can see most of the dust that way. Good luck.
Posted on Apr 26, 2010
My iMac has had a reappearing yellow vertical line down the left of my screen for at least two months now!
Maybe the video card. Try to spray with electronic contact cleaner the connections (pc cable to monitor).
Aug 01, 2012 | Apple iMac Desktop
3 thin verticle lines 2 pink and one yellow running top to bottom on screen
There is a problem with the monitor. Try resetting the SMC:
If that does not resolve the issue, it will need repair.
Aug 21, 2010 | Apple iMac 17 in (MA199LL160) Mac Desktop ...
Two thin lines (vertical) one blue one yellow permenantly on screen.
Try to check first if the video card cause these lines..
Turn off your computer, replace the video card and check if the lines still display..
If you still see lines, check the cable connected on your monitor to the video card, see if its properly secure and not loose.
If you still see it... then my suggestion is you bring your monitor to a credible technician..see also if your monitor still have its warranty
May 26, 2010 | Apple iMac Flat Panel Fan (p/n 922-4677)
My monitor has a yellow line running down the middle
This is a bad LCD panel. If it is still under warranty, your best bet is to have it replaced again. The only fix is to replace the actual panel and that would cost more than a new monitor.
Sep 28, 2009 | Acer H233H bmid Monitor
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Thin yellow line on the right of the LCD Screen
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
A very thin vertical brun line in the middle
If it's a straight vertical or horizontal line always in the same place it's a panel issue which the average user even with repairing skills will not be able to reliably repair ,Sorry.
Feb 25, 2008 | Dell UltraSharp 1905FP LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :(
Apr 21, 2007 | NEC LCD
Apple iMac G5 Desktop Logo
516 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
