Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber shot shutter problems
Hi, my cyber shot dsc w55 tells me to shut my camera off then turn it back on as my shutter is moving in and out. when i do that the lcd screens says access then to turn it off then on again. please help
  • spammers Jan 02, 2008
    When turning the camera on, it says access then says to "turn camera off and on again." Then when it is turned off and on it does the same thing.
  • Loucy1 May 30, 2008
    I have the same problem with my W55 and have trie
    d cleaning the lens and the whack with my hand and nothing seems to work. What now?
Occasionally, a good "whack" in your hand can fix it. Just don't hit the lens, or lcd; or you can break them. Then there will be more damage.
YES THIS IS STUPIDE SIMPLE AND IT WORKS! (owner of a DSC W 55)
Posted on Jan 03, 2008
  • 53 Answers
It may be as simple as cleaning your lens. If the lens is dirty your camera will think the lens is out of focus and keep trying to close. If you want to repair it yourself there is a guy in South Carolina who has lots of parts for all the Sony Cameras. I bought my LCD from him for $39.00 plus shipping and it works perfect. I put it in myself and saved a ton. If you buy the part from him he sends you pictures of him taking the camera apart so that you can repeat the process when you install it. I think his email is [email protected]
Posted on Mar 13, 2008
  • 34 Answers
There is a problem internally with the lens. Likely, the focusing lens is jammed up. The lens will need to be disassembled and fixed, if possible, or replaced. Occasionally, a good "whack" in your hand can fix it. Just don't hit the lens, or lcd; or you can break them. Then there will be more damage.
Posted on Sep 05, 2007
SOURCE:
How do i turn off the sound on the sony cyber shot dsc-w55?
Press the MENU button, select the toolbox-1 icon, select "Beep", then select "Off". For full details see the "Using Setup items" section beginning on page 50 of the Cyber-shot Handbook.
Dec 21, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
My camera keeps asking me to turn it off and back on again.
Start your camera to preview mode, not using the "on switch" Use the dial to set it to ISO selection, start it , IT should work, Now when your shutter is open see if it is dirty, If yes clean it, Now turn it off , And slightly press AROUND the lens shutter, "NOT ON THE SHUTTER", AND try if that solves the problem, I solved the same problem with my DSC-W55 like that only,
Mar 12, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Wy wife and I shake a little when taking pictures and our shots are fuzzy most of the time. what can we do to improve our pictures with this SONY DSC-W55 camera?
you need to increase your shutter speed. your instruction manual should tell you how to do it. if you don't use flash normally try using it with your pictures. If you can adjust the ISO setting to a higher number as well. Some digitals will let you and others wont.
Nov 27, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Replace Sony Cyber-shot DSC-W55 shutter button
Don't throw your Sony Cyber-Shot camera away!
We found a website who has created an entire comprehensive photo instructions for the Sony Cyber-Shot DSC-H Series Shutter Button Installation.
They also have the Sony Cyber-Shot DSC-H9 Shutter Button Installation Instructions as well!
Please note that we STRONGLY recommend using a flash discharger. This is for your safety and also for your camera's safety.
Hope this helps to get your camera working and start capturing memories again!
Aug 18, 2009 | Cameras
Sony Cyber-shot DSC- W55 takes blurry pictures
Hi!
The focus doesn't move as it should - it was stuck before you tapped it. Could be sand or something in it. I'm afraid you will have to give it away for a repair. You can contact your local Sony service center, but if they ask too much, I can offer you a very good price. My e-mail is [email protected]
I work in a Sony service center.
Hope this helps!
Tom
Jul 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I have problem with opening shutters
    Its a commen problem of DSC-W55  series.This is because the sleg motor start malfunctioning.To solve this problem you have to replace the LENS BLOCK ASSY.
You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Jan 22, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot 7.2 pixal ...Can I download an instruction book
You may download the manual and more from here. Make sure you get the Cyber-shot Handbook as well.
Dec 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
191 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
