Question about Toshiba Satellite M35-S456 Notebook
Error 0203 failure IDE #2
The Laptop Toshiba produces an error when trying boot from the bootable CD & an error occurs. error 0203 failure IDE #2
    Problem Solver:
  • 7 Answers
1) like always with anything that you do when taking your computer apart, take out the battery and unplug it (common sense)
2) Remove the plastic cover piece above the keyboard, called the "keyboard bezel". this is the piece where you can see the speakers. This page gives several pictures as to how to do this. http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-main...
**I found it a little bit difficult to get the plastic retaining clips to "pop" loose, but if you are careful, you can use a small screw driver and slowly "wiggle-pry" between the two screen mounts. this is done with the screen all the way back. you could use a paper clip with a little 1/8" bend at tip to do this also. (it is a tight working area) Once these three retaining clips have come loose the others are fairly easy to "pop" Just be patient and work it slowly. once this is bezel is off the rest is super easy.**
3) Remove the keyboard. Remove the two screws that are evident once the bezel has been removed. These hold the keyboard in place. Lift the keyboard up from the screw side and the retaining clips at the front of the keyboard will lift out. (there is no need to pry here). Once the keyboard is loose you will have to either leave it connected, just off to the side, or disconnect it from the mother board. The keyboard cable connector has a black clip along the top of it. just lift this clip up a little and the keyboard cable will slide out. (the keyboard cable does not have a fixed connector, but is just a ribbon that is held in place by the black clip along the top of the keyboard cable connector) Once you have removed it you will better understand what I mean.
4) Remove the wireless card. It is the only card visible at this point. It is connected by metal spring clips. just unclip in a similar fashion as removing ram. You do not need to disconnect the wires connected to card, just move card over to expose area below card.
5) This is where the magic is... you will see C88 clearly labeled right next the jack that the wireless card plugs into. There are two little solder squares (approx 1/16") at this location. *** At this point plug the power adapter to your computer again. ***
You will have to jump the two solder squares at label C88. I used a paper clip to do this. I used pliers to bend a 1/8" long "L" and then "scuffed" up the paperclip with the teeth of the pliers. (my first try at this did not work because the paperclip had a varnish coating on it and did not adequately conduct electricity.) Once you have your paperclip set up (or the one you used to pry the bezel with) hold it in place on these two solder contact squares and press the power button to boot your computer.
6) Your computer should boot right up and bypass the bios password, which is now reset/ erased. (You might see the Windows Error startup screen that gives you different options of start up to choose. If you disconnected your keyboard, just wait for screen to time-out and it will continue on its own) Once you have booted into windows use your mouse pad to shutdown, via start-shutdown method.
7) Disconnect your power. Reinstall your wireless card and keyboard (with screws). Don't reinstall keyboard bezel at this time. Once everything (but bezel) is reinstalled, restart the computer with battery and AC adapter connected. This should boot right into your computer without any trouble. (if for some reason it does not boot up correctly and asks for the bios password again you will be glad you left the bezel off. just redo the steps again.)
Posted on Apr 06, 2009
Try re-burning a new copy of that bootable CD. It's possible the Bootable CD didn't burn correctly or maybe the image is bad.
Jul 24, 2012 | Computers & Internet
Arthur,
That problem can be a couple of things.
The CD/DVD Drive may be failing ,or the actual IDE Controller built into the motherboard is bad.
You will need to determine which it is.
To do that - find an identical computer and see if you can remove the CD/DVD Drive from your laptop and swap it with that computer's drive. Then try to boot up your laptop with the "Known Good" drive in the system. If the same error occurs - then you will know that the IDE Controller on the motherboard has failed.
You can try to upgrade your system BIOS and this might trick the IDE Controller back into working, but it is a slim chance. Try it anyway.
(For details about swapping the CD/DVD Drive on your laptop, visit the toshiba website to get the instructions. Also, on the same website you can download the BIOS executable to attempt to run. The website is: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=556042&rpn=PSM30U&modelFilter=M30-S350&selCategory=2756709&selFamily=1073768663)
Hope that helps!
Nov 26, 2011 | Toshiba Satellite M30 Notebook
My laptop wont boot up and goes to a system error with run set up and boot menu if you go to boot goes to the windows xp screen and then back to the system error 0203 faliure ide #2
Windows is totally corrupted and you must reinstall it. So either select the recovery partition from the boot menu or put in the recovery cd and select it and follow the instructions.
Jan 15, 2011 | Computers & Internet
AM GETTING AN ERROR "0203
First try restarting while tapping the F8 key to try and both from disk this way.If that doesn't work you will need to try and install the drivers for the ide controller and cd rom . if all else fails you may need to try replacing your dvd/cd drive it has failed for one of the above reasons.
Dec 01, 2010 | Toshiba Satellite M35-S456 Notebook
Toshiba Satelite M35-456 Error 0201 Failure IDE #0
Here is the Toshiba official line on that error.
If you've already run through their fixes, you could try using the Ultimate Boot CD to test the hard drive, or run Chkdsk c: /r from the recovery console to attempt to recover any bad sectors
Then consult this link and apply the pertinent fixes to attempt to repair the MBR.
Other possibly helpful links here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 17, 2009 | Toshiba Satellite M30X Notebook
Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Feb 08, 2009 | Toshiba Satellite M30X Notebook
Toshiba Satellite laptop boots up but shuts down on its own very shortly
Hi JOJO0803,
Based from the error message you're getting it sounds to me that your problem there is not software related but is more hardware in nature.Since you're getting a message "disk read error occurred IDE#0" this pertains to a problem with the hard drive itself. It's possible that your hard drive developed bad sectors or errors on the disc itself.
So to be sure I would recommend that you run the hardware diagnostics for your laptop computer especially the one for the hard drive since you're getting this message. If the hard drive fails the test or any other part fails in the test, contact your techsupport and ask for replacement parts if your PC is still under warranty. Otherwise you may have to buy parts for your laptop.
If the hard drive tests passed and all the other hardware tests also passed then you may proceed to troubeshoot the software using the Windows XP Home CD. Boot from the WinXP Home CD, and you get to the setup screen, choose "R" for recovery console and then on the prompt type "CHKDSK /R" let it run, it may take a while. afterwards it will bring you back to the prompt then type EXIT and it will reboot the system, see if that fixes the problem. Worst case scenario you may have to format then reinstall Windows XP again to fix this problem.
Hope this helps!
Peace! :)
Oct 23, 2008 | Toshiba Satellite A105 Notebook
Disk error
Does the laptop have a usable cd/dvd rom drive?
May 13, 2008 | Toshiba Portege 3505 Tablet PC
New Laptop Optical Drive Causes 0203 failure ide #2 error at boot
it's in the bios, hit F2 when it's booting, and go to drives, and set it from there..you will see them..you may need to turn them off, and then restart, then F2 again, and then turn them back on.
check your computers warranty here 4 FREE
Mar 13, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite M35-S456 Notebook Logo
2,518 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
