Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
The pressure left the group!
By bilos77 on Apr 06, 2009
I have a commercial brasilia gradisca and the water pressure stopped to build up at the exit of the group insted it goes to the over flow... Is there an ajustemnt screw...
Solution #1
posted on Apr 06, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 366 votes
Check the top of the group, you will find a nut which is about 19mm, within that nut is a micro-screen, and a small jet. Make sure the machine is cool and the inline water is turned off. The jet maybe clogged, get a paperclip or some pipe cleaners and clear, check screen for buildup, there might also be a small amount of sand in there(Minerals from the water), easiest way to clear it slowly open the inline water. BEFORE REMOVING THE NUT CHECK TO SEE IF THE GASKET UNDER IT IS TEFLON OR SILICONE. IF TEFLON GO AHEAD, IF NOT MAKE SURE YOU HAVE ANOTHER ONE ON HAND BEFORE YOU PROCEED.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
the pilot still on but when i turn it to on position and i try to set a temperature it goes away
Answer
it fell on bathroom ceramic tile floor and doesn't work at all
Answer
My Bunn B10 coffe maker leaks from the bottom Where would I order the part to correct this?
Describe your Coffee and Espresso... problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in Sedona, AZ
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
