Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Wont turn on
When i push the power button it flashes and turns off. it has been loked at and was told it was in high voltage mode. it was left unpluged for a month while i was waiting for a call back from the repair place and i recently tried it and it worked for a day and is back to being broke. please help
  • 1,139 Answers
Re: wont turn on
Who ever told you this was right the TV has a HV problem and that is why it is shutting down. I would suggest that you get one of the shops on to take a look at the set for you. I have worked on a lot of these sets and I can tell you that it will not be cheap.
Posted on Sep 08, 2007
0 characters
3 Points
Rca p52738wk projection tv has power but wont turn on button will flash and keep clicking so its got power but tv wont turn on
Possible there is a short within the outputs and so the power is tripping off when switched as a protection since the chances of damage is more.
It will require a voltage check on the motherboard to confirm if the +B voltage comes up and fails. If you trace the +B it will lead to the fault condition. In most cases if the switch on is repeated you can notice the heating of a driver or component which can confirm the fault. Once the short or the drain circuit is removed the +B will be stable.
Make sure that precaution is taken when testing high voltage circuit.
Oct 04, 2011 | RCA Projection Televisions
Turn power on and all it does is stand by light flashes ten times over and over tv does not come on and i have to push power many times to get it to turn off
This could be a couple of issue.
1) Power supply problem.
2) This is a CRT rear screen so it could be a High Voltage issue. Possibly a faulty HOT 'High output Transistor' that supplies the high voltage to the CRT's.
Good to get it into a trusted service shop.
A/V Media Tech Guy
Dec 19, 2009 | Sony Grand WEGA KDP-57WS655 57" Rear...
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Power button to tv
i have a friend who has this tv and the same problem. i called a repair shop abd i was told it is the high voltage converter. $400 to pick up drop off and repair.
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on
the rca itc222 chasis has no front led diagnositc codes. Does the led flash imedatly when you plug it up. or does it start when you push the power button. if it does when you first plug it in then you have a problems with what is know as standy voltages. voltages that are always there when you [lug the set in. the processor does not see correct voltages. now if this flashes occur when you oush power button then there is problems with the secondary voltages also known as run supplys. does the set try to turn on do you hear static.. if not then you might have high voltage flyback or horizontal output problems.
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV won't turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 25, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Wont turn on
Hi ,your trouble could be a 2200 35v cap on the high voltage power supply,its in the middle of the board behind a little u shaped heat sink,the cap is green and if its bad the top will be pushed up,hope this helps
Oct 14, 2007 | RCA D52W19 52" Rear Projection Television
Hitachi rear projection "61UWX10B
I was told may be problem with high voltage capacitor. not true. 1 your problem in power supply. 2 if it is ok it is due to horl.section.
Sep 14, 2007 | Hitachi 61UWX10B 61" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
