Question about SanDisk Sansa e250 MP3 Player
Sansa c200 My sansa c200 won't turn on or charge. I bought a new battery and a new power cord. Nothing happens when I try to charge it. When I put the new battery in it would play but I couldn't load songs. I thought it was the cord so I ordered a new one. Now the battery is dead (I guess) and the screen stays black when I plug it into the computer. barbara
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
120gb Zune won't turn on or charge
No probley not it needs a new battery more than likely they can be bought for around $25.00 or so no fun to put in very delicate.
Sep 29, 2017 | Microsoft 120gb zune digital player /...
Charges but lights flicker when trying to turn on then lights turn off and nothing happens.just bought new charging cord oem.
Not all oem's are created equal, this sounds like a power supply issue. I would be tempted to try another power supply, first remove the main battery and press power, if it comes on the rechargeable battery is bad, replacement only option.
May 03, 2012 | Toshiba Satellite A105-S4284 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Not charging
Try connecting directly to USB port on your computer, NOT a hub. It needs power to charge.
Apr 29, 2009 | SanDisk Sansa c240 MP3 Player
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
It´s dead
hey buddy just do one thing.. open the metal cover removing the 4 philips screws.. and then remove the battery then reinsert the battery and try.. it should work ... i had the same thing few days back.. it was charged and in my pocket when i tried to listen to it the damm thing wont switch on .. so i removed the batter and put a LED to the terminal to check power and inserted it back it and valaaa it hot and running again..
Jan 25, 2008 | SanDisk Sansa e250 MP3 Player
C200 dont charge
Try changing the battery.
Dec 16, 2007 | SanDisk Sansa c200 MP3 Player
Charging sansa c200
u're not doing nothing wrong, but you should take it to where it was bougth 'cause it can result in something worst than just the batterie
Nov 25, 2007 | SanDisk Sansa c200 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
