Mayosoma, on bootup, when I login into Windows : the letter keys (J,K,L,I,O,M) populate numbers now - by default, enabled. This option was not enabled before and now it has mysteriously enabled itself. Nothing on my computer has changed since this started happening. Hope that gives more insight to the issue. Thanks for your quick response.
Sounds like you need to go into your BIOS and remove the option of num lock on power on. Good luck.
Then try this if you have XP or 2000
Run the Registry Editor (REGEDIT.EXE). Open HKEY_CURRENT_USER\Control Panel\Keyboard (If the Keyboard key isn't there, add it.)
Double-click the InitialKeyboardIndicators value on the right. (If it's not there, select New from the Edit menu, then String Value, and type InitialKeyboardIndicators for the name of the new value.)
Change the value to any of the following:
Or, combine them by adding the corresponding values: 0 - all indicators off
1 - Caps Lock on
2 - Num Lock on
4 - Scroll Lock on
3 - Caps Lock and Num Lock on
5 - Caps Lock and Scroll Lock on
6 - Num Lock and Scroll Lock on
7 - Caps Lock, Num Lock, and Scroll Lock on
Close the Registry Editor when you're done; the change should take effect the next time you start Windows.
Please note that this worked for me, however I work within the registery very frequently. If you should smoke your computer or it turns up pregnant, I won't take responsibility. I am just giving ideas. If you do them, then that is your issue. (Sort of disclaimer...)
Function (FN) and Number (NM) tapped at the same time should shut that off.
FN + NM is the quick fix for that but I am looking for a permanent solution so that I don't have to keep pressing that combo - Keep in mind, this was the origianl option and it has mysteriously changed
Iamscott - I originally tried that in the BIOS - I am still looking for answer. Thanks for your response
After a huge forest fire and twins on my laptop - the mysterious "num lock" has dissapeared on Boot-up :) Great Job! Thanks for your help!
