Question about Kenwood KVT-M700 Car DVD Player
Menu icon does not work properly
Everything work except menu icon. icon is situated where it belong but can't use it it seem like the icon is there but accual touch pixil might be above the plastic frame. help!!!!!
Try this it may help. First, reset by pressing both VOLDW & SRC keys at the same time and boot up the system in Test Mode. Display the Touch Adjustment Screen with the SRC key of Car TV remote controller, press center section of the "Cross-font" using adjustment stick. (Upperleft - upper right - lower left) Note: When conducting the adjustment for the first time, the display position of the cross-cursor may be little off, but the adjustment should be conducted by using the center position of the font.
Posted on Sep 05, 2007
  • pompeylad2k Sep 08, 2011
    Bought the remote, am able to get the unit into test mode (appears red and shows where you are touching) but how do you get the touch adjustment screen using the src key on remote? Mine just flicks through av, tuner, all off? I know you posted 4 years ago, but you seem to know more than anyone else I have asked? Thanks
SOURCE:
Smar thru icon not showing in my desktop whether printer is working properly
I presume you have Windows 7, right? If everything else is ok - printer working properly, you may drag the SmarThru icon form the start menu on your desktop.
Sep 27, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I disconnected my phone from the charger this morning and it went to a black screen with no background and no icons.i can still get to all of the items on my phone but only if i open them from menu...
It appears the software to display the touch icons became disabled. There are of course ways to re-enable it, but since you did not write whether you got your phone from htc or by any provider, I am not sure which software this is on your device.
A solution (albeit not the quickest one) is to a complete backup of the phone to sd card (there are programs for that, check out spb backup for a start), then doing a hard reset (like re-formatting the device - you can find it on the settings->system menu, it's called something like erase everything). This will revert the phone to factory default (including a working touch icon application)
After that you restore the backup to get all your data back.
This should solve it.
Aug 13, 2010 | HTC Touch Pro Smartphone
Menu icon on screen can't reduce to normal
Simply use 3 fingers to double-tap on your iPod's screen to put everything back to their normal sizes.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
Jul 28, 2010 | Apple iPod touch
I have somehow deleted the icon for settings on my phone and do not know how to restore it
don't worry
i will tell u how to handle the situation.
goto help icon on main screen
select menu->applications menu->scroll down,touch settings->from top of page select open settings->
you are into settings menu
select phone->phone mgmt->factory settings
restore your original settings.
YOUR PROBLEM IS SOLVED
Mar 15, 2010 | Nokia 5800 XpressMusic Smartphone
Everything works fine with windows 7 except I can no longer scan anything can this be fixed?
The HP website states that some functionality with your printer model may be lost when using the Windows 7 preloaded drivers or Windows Update drivers. If you have not already done so, running Windows Update, to include optional updates, may supply a more appropriate driver for your printer. You can do this by pressing the Windows (28f534a.gif) icon then All Programs and then Windows Update. Click "Change Settings" to make sure that the "Give me recommended updates the same way i receive important updates" box is checked. After this, run the update to see what comes up. Ideally, you should run everything that comes up in Windows Update except the language packs, especially hardware and important updates.
If you have already done this, there are two methods you can use to scan. I have listed them below.
  1. Click the Windows (3d374c9.gif) icon.
  2. Click All Programs
  3. Click Windows Fax and Scan
  4. Click New Scan, and then click Scan.
Another method is to use MS Paint to import an image from your scanner.
  1. Click the Windows (07d5258.gif) icon.
  3. Click Accessories
  4. Click the Paint icon
  5. When it opens click the menu (d2c91dd.gif) icon
  6. Click From Scanner or Camera
VOILA! You should be all set!
Good Luck
NOLA Tech
Jan 28, 2010 | HP Officejet 4215v All-in-One Printer
HTC Touch Pro LCD Going black and then sometimes working
is there the "calendar" and "contacts" menu buttons on the bottom of the black screen?
that's what would happen to me. i just turned off the touchFLO 3D on the today screen (by going to settings, then today screen options) and it seems to not go black anymore... even after being untouched for hours.
not sure if the same thing is happening to you, but it worked for me.
Jul 19, 2009 | HTC Touch Pro Smartphone
Kenwood KVT-M700 Car DVD Player Logo
309 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
