I have a Hunter fan - the light works fine, but since we moved in, the fan has never worked - except once! That one time, I had turned the light on . . . some time later I saw movement out of the corner of my eye from across the room . . .the fan was going! I went over and turned the light switch off and back on again - and the fan stopped and wouldn't go on again. The remote doesn't work either! It is the Sojourn 21182 . . . .
I have a Dimplex BF5000 electric fireplace. The fan does not spin but I still get heat from the...
(More)
I have a Dimplex BF5000 electric fireplace. The fan does not spin but I still get heat from the heater assembly. I have open the cover and cannot see any obvious wire problems.
Light bulb must be out. Cannot remove glass at the very bottom to access bulb area in order to...
(More)
Light bulb must be out. Cannot remove glass at the very bottom to access bulb area in order to install replacement bulb . UL 96H7 E 77491 Model 54 SHRL 11688 09/04 0041681
we have an electric freestanding fireplace made by SOuthern Enterprises, model # FA503000 TX. it has...
(More)
we have an electric freestanding fireplace made by SOuthern Enterprises, model # FA503000 TX. it has totally quit working. I was working one day, then nothing the next. I thought maybe it had been unplugged, but everything is plugged in correctly. Is there a fuse or something somewhere or batteries that we may could check? Obviously, we have lost the manual. Thanks for any feedback you can give.
Trying to install new hunter 44155c...my old thremostat has diff letters...I have B,G,Y,R,W and...
(More)
Trying to install new hunter 44155c...my old thremostat has diff letters...I have B,G,Y,R,W and O...could you please help me with the new one on where these wires should be placed
My heater's internal thermometer is too sensitive. It shuts itself off after being on for only a...
(More)
My heater's internal thermometer is too sensitive. It shuts itself off after being on for only a minute. This is supposed to be a safety feature, but it means that I can't use the heater. Any suggestions?
