Question about Brother LS-2125 Mechanical Sewing Machine
How to change a needle
Ive tryed everything! how do i change the needle!
  • larosa Dec 23, 2007
    my sewing machine is a singer advance ,and my needle broke and I don't know how to change it.
    President:
  • 1,114 Answers
You can download the manual from the link below: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_ls2125eus.html?reg=us&c=us&lang=en&prod=hf_ls2125eus There is also a FAQ section that may help you. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 05, 2007
Bobbin thread is jamming machine
it indicates that you have a situation called " bird nesting" and that is a result of the needle thread tension being too loose
needle tension should be tight so that when you pull the thread to thread the needle you have to exert a bit of effort to pull the thread through the tension plates
you can adjust up or down from that feeling
thread thickness affects the tension and needle eye size also affects the tension as a small eye on large thread makes the thread movement hard indicating less tension or a big eye on a small thread affects the tension as the thread slips easily and needs more tension to pull the bobbin thread up to the centre of the material being sewn
Dec 20, 2016 | Brother Sewing Machines
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
Sewing Machine Thread Keeps Breaking
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Apr 03, 2016 | Sewing Machines
I am quilting and the thread keeps breaking. What is the problem?
Not sure if you are piecing or trying to free motion quilt. If FMQ, try using an Embroidery needle (it has a groove in the shaft that helps protect the thread) or a Topstitch needle. Make sure the thread is not too thick for the needle's eye. Check to make sure the upper and lower tensions are not too tight. You might try changing brand/type of thread.
Here's a needle guide:
SCHMETZ Household Needle Chart
Or review suggestions for breaking thread here:
Why is my thread breaking
Hope this helps!
May 20, 2015 | Sewing Machines
Ive got a singer sweingmachine 247 model no when i put the bobbin in the bobbincasing with tread and guide so the needle goes down to bring bottom tread up nothing happens it doesnt feed it to come up i...
try changing the needle
try rethreading the machine, make sure the presser foot is in the up position
make sure the bobbin is turned correctly in the bobbin case,, counter clock-side
also could be a timing problem
Dec 22, 2014 | Singer Sewing Machines
Top thread will not work ive tryed changing needles is there a special needle to use
the needle used depends on the fabric being sewed. the needle must move thru the needles eye smoothly.
make sure the machine is threaded correctly, using every thread guide
make sure also the bobbin is wound correctly and that the bobbin is inserted into the bobbin case correctly, if the bobbin is turned the wrong way the machine wil not sew
here is a link for a free manual, if you don't have one
http://www.singerco.com/uploads/download/756_white-3300-emb-x.pdf
Sep 07, 2013 | White Sewing W3300 Computerized Sewing...
My sewing machine will not stich. i have tryed everything i can find on this problem but nothings working
Make sure nothing has either gotten stuck/caught/jammed somewhere inside it. Insure that the thread stays attached to the needle. Or the material you are trying to sew/stitch may be too thick.
Nov 17, 2012 | Singer Sewing Machines
Im trying to hem a pair of jeans when i start it jams up im using a number 16 needle ive checked everything twice ive even called the help number and they couldnt help me i just dont understand what the...
If you think its the way the material is being moved, I would check the pressure on the presser foot. On my machine, there a knob with 1,2,3 to adjust, its vertically above the foot on the top of the machine(Check you manual). Sometimes the jeans hem is just too thick on the side seam. I just skip that part, or move the needle through that part by using my hand on the wheel, so the stitsches look ok, but it should do the rest of the hem fine. Try the thinnest part of the hem first; good luck
Sep 14, 2010 | Kenmore 12912
White serger 2000
Did you change to the narrow stitch finger? The narrow one is in the door of the machine where the other tools are -- a little square box on the left of where the needle box slides in. Sometimes that is needed instead of the normal one.
Caution: If you have never before changed it out, open the left door all the way and look and see where the stitch finger is coming out of before you remove it all the way. Refer to your manual.
Oct 13, 2008 | White Sewing Superlock 2000 ATS Mechanical...
Breaking needle
Sounds like the timing is off, have to take foot off, take plate off, put it in the zz position and using the hand wheel turn(with new needle in) and see where it is hitting feed dog, loosening the screws to the feed dog and moving it in the opposite direction out of the way so as not to hit. let me know how that works
Aug 08, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
