SOURCE: i mhave a cybershot dscwx7
Welcome to Fixya
I was not a able to find an LCD replacement for this particular model. What i can provide you as of the moment is the procedure on how to replace the LCD screen. Please see steps below:
Turn off the camera and remove the battery. Remove all the small screws from the camera casing using precision screwdriver. If the camera has a locking ring, filter or lens adapter attached to the front of the lens, remove these components.Pry the camera apart carefully. The camera will come apart in two sections, with the front section containing all the electronics and the LCD screen. Lay the front section down on a table, and remove the small screws holding the LCD screen in place. Lift the screen out, and follow the ribbon cable to where it connects to the circuit board assembly. Pull out the plug for the ribbon cable, and hold LCD screen. Insert the plug for the new LCD screen into the circuit board. Position the new screen onto the circuit board. Replace and tighten the screws. Reassemble the camera, replace the screws into the camera housing and insert the battery.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
