Question about Toshiba Satellite U205S5067 Notebook
Reset settings moved to a new apartment and wireless internet no longer works
  • 63 Answers
How was it working at the other apartment? Do you have a wireless router? Which ISP do you subscribe? Were you connecting off the neighbors? Need more info to successfully help you with your issue.
Posted on Sep 06, 2007
SOURCE:
Why is it that wireless printing using same hardware and service provider will no longer work at new address and SP account?
When you say :"identical" do you mean the same unit, or another unit of the same model? I experienced the same issue after moving, with a new "identical" model modem/router provided by the ISP. Until the provider replaced the router with another "identical" one I couldn't get the wireless printer (HP in my case) to connect no matter what I did either using the WPS function or entering my network settings manually. Other wireless devices worked okay.
Sep 09, 2014 | Canon MG3170 INKJET COLOR ALL-IN-ONE...
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
Network is "out of range" only after securing my wireless network
reset your router
should be a reset button on the back,
hold in till the lights on the front flash then its reset open explorer browser
type in 10.1.1.1 or 10.0.0.1
log in as Administrator
add new user
set password while adding new user
save your new settings(write them down too)
run your network wizard again with your new settings applied
test the internet for function
if no function then contact your ISP to assist with connection to internet
all sorted now please rate me MISTERDJ
Apr 11, 2010 | Toshiba (PA3070U-1MPC) 802.11b Wireless...
Moved, new internet hook-up, lost IP number
firstly try calling ur ISP provider may be they will help you if not then its a simple rule connect the router to the modem and modem to the system tower or laptop
Aug 24, 2009 | Linksys Wireless-G WRT54G Router
Wireless router connection problems
That is very possible. I would reset the router by reset switch on back. Also both routers will tend to build up a static charge loosing the connection. You can unplug it for 10 seconds and replug in.
I would also try setting up new home network using automatic settings.
Jun 23, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Wireless Internet stopped working. Can't reconnect.
If restarting the router and restarting computer did not work (unplug both power cables), then you need to log into the router and check network settings.
To log into router type the router IP on internet explore bar, then enter user id and password.
You find details on how to do this, IP and passwords listed on the owner manual.
If wireless security settings on router are fine, then you can reset router to factory default using the pinhole switch. You will need to enter all your broadband settings to have the router working afterward.
Apr 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Version 1.1 internet works for 5 min and stops.
First thing to do here is to reset the router and reconfigure it back using the setup CD and hopefully it will reconfigure the router but if still didn't not make it work better call Linksys tech support and let one of their tech to walk you through it checking the router and also updating the software for it , they are open 24/7 this is the number 8003267114...
Hope that helps..............
Sep 18, 2008 | Linksys Wireless-N WRT150N Router
No Broadcast
When you reset your router you deleted the settings you need to go through the setup of the router once a gain.make sure the cat5 cable is connected to the pc your setting up. make sure your wireless is not to far away from the router and see if the connection stays longer then.
Feb 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Internet will not connect through router.
Hello Orionj2
We can provide you with the best Comcast internet tech support, so if your Comcast internet is not working fine, then you just have to get in touch with support. Call us today and get internet related issues fixed.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
Sep 20, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
