Question about 2wire (1000-000057-000) Modem
Broadband 2nd Light keeps blinking yellow and then a solid red Light
Can't figure out why the Blinking 2nd light - Broadband connection light keeps blinking yellow and then turns red. Can't connect to internet. It is my parents computer/modem. Do you know what may be the cause?
  • wcam Sep 10, 2007
    Thanks!
    Sergeant:
  • 457 Answers
Ask your Paents to ring the company they connect with it seems to be emulating a disconnection for some reason?
Posted on Sep 09, 2007
SOURCE:
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 15, 2016 | Televison & Video
Have solid red light at the 7 o'clock and blinking red light at 11 o'clock
[PDF]Download XD1080 User Guide - Replay XD
www.replayxd.com/downloads/.../Replay-XD1080_User_Manual-EN.pd...
Note: The red LED on the rear will blink when the memory card is not inserted .... The Start REC button should always point up or at the 12 o'clock position for a ...
LG TV Blinking - YouTube
? 0:43
https://www.youtube.com/watch?v=Q8JG53DU6Rk
Nov 5, 2015 - Uploaded by Gillet Gaming
My TV suddenly started blinking when I turned it on at 12o'clock. ... I was going to use it when a few ...Missing: p
Diamond - ndxLocOut
www.nuforc.org/webreports/ndxsdiamond.html
11/7/15 18:05, San Diego, CA, Diamond, 5 minutes, Orange Diamond like .... 8/23/15 21:08, Wildwood Crest, NJ, Diamond, 2 minutes, Hovering red light, ... Diamond shaped brilliant white light with red light in eastern sky at 12 o'clock ..... flashing blue yellow the red at times staying solid red or blue seems to get bigger. 2/27/ ...Missing: p
[PDF]Air-Pak 75i SCBA - User Manual - Scott Safety
Dec 21, 2015 | Televison & Video
Red light - Internet
Not internet connection. You will need you IP to come check the lines.
Nov 14, 2017 | Zyxel Computers & Internet
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
My check engine light keeps blinkin on my 2003 chevy impala and keeps shakin
Take it in, a blinking check engine light is not a good sign. Solid yellow is ok, blinking yellow or red is in need of service. Get the codes checked asap.
Feb 12, 2011 | 2003 Chevrolet Impala
Yellow ink blinking
Please clean the printhead using the software installed in your PC . Try printing now.
Apr 30, 2010 | Epson Stylus Photo R2400 InkJet Printer
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Blinking yellow light similar like this (8~)
It means there is a paper jam in the machine.
May 21, 2009 | Lanier Office Equipment & Supplies
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Its disconnected ring the ISP or your Parents?
Sep 04, 2007 | 2wire (1000-000057-000) Modem
2wire (1000-000057-000) Modem Logo
538 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
