EVEN THOUGH MY LIGHTER PORTS ARE HOT MY UNIT WON'T CHARGE WHILE PLUGGED IN. I SHOW CONTINUITY TO THE CONNECTION ON THE WINDOW VACUUM DEVICE. THIS SHOULD MEAN THAT THERE IS SOMETING WRONG BEWENN CONECTIONS AND BATTERY. AM I RIGHT AND WHAT SHOULD I DO.
Yes you are correct, it looks like your accessory power socket is working. 1: try resetting the device, peel back the silver screen surround to find the reset button. 2: make sure it still charges from your home charger if you have one. 3: clean the plugs and charging socket on the device with an alcohol free CD wipe. 4: borrow a car charging cable if you know anyone with the same device or replace the cable if not. message back if this is no help. FYI typing entirely in capital letters is considered shouting in textual communications.
I am having the same problem. When I turn on the car my GPS turns on but the batt is not charging. If I remove the GPS from the cradle or turn off the car, the GPS turns off and it is unable to turn back on.
I will try the suggestions listed here.
