Question about HP PSC 1210 All-In-One InkJet Printer
Check paper light is blinking, there is no paper in the feed, checked to see if there was a jam, nothing.... The 'copies' constantly shows an E?
  • Anonymous Feb 09, 2008
    I have the exact same problem wth my HP 1210 printer. The printer heads also made loud cranking noises and moving back and forward (not sure if that's just normal when you turn it on or press resume.)
The above solution does work. I have the exact same problem.
Posted on Feb 09, 2008
  • HP Master
  • 2,022 Answers
Put the paper in paper try properly like put deep inside and stop it when you feel littel bit of resistent put slowly inside the paper.
Posted on Sep 22, 2007
Show e on copies and check ink cartridge light is blinking with new ink cartridge
With "E" ,check cartridge LED which is blinking mono or color replace it, or else check paper LED if its blinking check for the paper jams..
Sep 27, 2011 | HP PSC 1210 All-In-One InkJet Printer
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back...
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
Jul 19, 2017 | Canon Office Equipment & Supplies
I have a HP 5550. I had a paper jam and after I
Choose your printer from this list, go to solve a problem, and see errors on the product or search blinking lights.
If you still have trouble, see reset printer.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 25, 2009 | Office Equipment & Supplies
Paper feeds half way, then check paper light blinks but no jam!
Try cleaning the rollers at the bottom where the paper feeds in from and that should help.Now if this does not resolve the issue then trust me call in to hp total care at 1800-474-6836 and get a discount of atleast 50% on upgrade printers nothing less that 50%
Jun 15, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
Both paper and cartrige lights blink & E in coppies won't leave
just replace the cartridges its the cartridge replacement error .or check out in the printer for any paper jam that also gives this E error on the printer.but mostly its the cartridges error.also try cleaning the cartridge before replacing them sometimes the cleaning helps.
Dec 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
HP PSC 1210 All-In-One InkJet Printer Logo
122 people viewed this question
Ben Johnson
