Question about SanDisk Memory Media
1Gb SD Card
Hi, I've downsized a bunch of photos totaling about 423 Mb to put on my card, and the card will only load between 16-27 Mb before it says that it's full. The dialog box shows that there is over 900Mb empty space. I've tried this with two different cards with the same result. Both cards work fine in my camera, so it must be something I'm doing wrong, but I haven't a clue what it may be. I'm running OS X 10.4.10 on a Intel iMac Help! Thanks, Greg
  • logdog Sep 05, 2007
    Hi again,
    Nope, didn't work. I get a dialogue box that says it can't copy any more because the card is full, but the card's dialogue box says there's 968.2 Mb available. When I click on "OK", the photo files that have just been put on the card are erased, so basically, I can't get anything at all to stay on the card. Jeez.
    Greg
    Novelist:
    Scholar:
  • 114 Answers
You have a hidden trash file on the card, emptying the system trash with the card mounted will also empty the hidden trash file on the card. To prevent this kind of issue and issues of your hidden system files showing up in windows, you can use a clean eject tool such as FinderCleaner www.macupdate.com/info.php/id/16996 to clean off all the hidden system files before ejecting the card, this is not strictly necessary and nor does it cause any harm it just prevents issues associated with these files.
Posted on Sep 05, 2007
  • Nicholas Wilson
    Nicholas Wilson Sep 05, 2007
    In finder click Go, then click Utilities, then click Disk Utility and Format the card, if you intend to use the card with anything other than Mac OS X make sure you format it as FAT32, otherwise use HFS+ to considerably increase speed. Disk Utility also offers you a Verify Disk option so use this to check the card's integrity and post the result here.
    To be honest if this doesn't resolve it then you have a hardware fault with the card and it will need replacing.
    I am extremely surprised this wasn't the old trash issue as it usually is with the symptoms you described. The trash issue catches every inexperienced Mac user out because it's not an issue common to Windows.
SOURCE:
My memory stick of 1gb has full memory filled and now i m unable to see the photos loaded in it through the camera or the card reader
That means the memory card was corrupted. You need a memory card recovery to recover photos before seeing it. I recommend you use Card Data Recovery, i can recover data from corrupted or damaged memory card.
Aug 28, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
Unable to locate a 1 MB SD card for my camera, in my area.
There's no such thing as a 1 MB Sd card. Do you really mean a 1GB SD card? Try amazon.com
Aug 27, 2011 | VuPoint DC-M306AT-VP Digital Camera
My model is SD 10. Sofar I had 256 MB memory card in that camera. Recently I put 2 GB card. After somedays the camera take long time for processing. Finally in the photo taken day light, I can see only...
switch to a sd card of less than 2gb as your camera's internal image processor power is being used in running or reading the huge 2gb sd card ...and that is the reason the image izz getting white ...try for 1gb or less ..
Jan 31, 2011 | Canon PowerShot SD10 / IXUS I Digital...
I ve 1gb micro sd card which i use in my fone.now when i try to read the data through card reader and it cant be read My 1gb SanDisk microSD memory on my computer.
take the card to asda and ask if you plug it into there memory reader where they print photos to see if it opens.if it does it is your reader at fault.
Jun 01, 2009 | SanDisk 2GB microSD Memory Card
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
SD card(s) - not enough free space?
Formatting the SD card to FAT32 instead of FAT16. Also, when the card is in the reader & you're looking at it on the Mac, empty the Trash while the card is still plugged-in.
Mar 10, 2009 | Computers & Internet
2gb sd card but available only 1gb
levyveress,
Well you have a 1GB SD card, there are roughly 1,073,741,824 bytes max per gig. They vary slightly from USB flash drives it total bytes, but the number should be 1,930 (or something close) MB for the 2Gig SD card, bring it back it may have been mislabeled on the packaging.
randy320sgi
Jan 17, 2009 | SanDisk 2GB microSD Memory Card
Tungsten E2 sd card - photo's
They won't. Your SD card has to be installed in your E2 and you have to load the pics (multiples if you want using your media icon on your desktop software. There are more steps which I know by heart. Do you have the desktop software?
Oct 19, 2008 | Palm Tungsten E2 Handheld
Sandisk Sansa e130
I have a 1GB SD card in my E130 Sansa. I had fill it up to 998MB. The only problem is that I have to leave 3MB in the flash unit. I guess it need it for constructing the Music Library.
The Flash (512MB) and the SD card (1GB) are both in FAT32.
I guess that it may be a problem of the SD card itself and not a problem of the Sansa.
1) Have you tried to read the SD card with a card reader (without the Sansa)?
2) Have tried formatting the SD card (not a quick format, but a real one) in FAT32 (be careful about that).
talueguito
Sep 03, 2007 | SanDisk Sansa e130 MP3 Player
Electronics - Others Logo
91 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
