Question about Sharp AR-5316 Advanced Digital Imager Copier
Copier prints light like paper is damp
My copier prints light, like the paper is damp, for the first 10 copies, then prints normal. If I leave it for 10 minutes, it starts printing light again. What the? It is a Konica Minolta 7222, which is not listed but I figured others may have the same problem.
  • vvvjulzvvv Sep 06, 2007
    Thanks Bill, But it is not a damp paper thing as I have tried paper from several different reems.
  • 30 Answers
Damp paper is indeed you problem. The top sheets in the paper drawer will absorb moisture and that moisture will prevent the image from completely transferring from the drum. If you want to test the moisture hypothesis, just open a fresh ream of paper and you should see and immediate improvement. If not, then we need to look elsewhere. Let me know if it works. Aloha, Bill
Posted on Sep 05, 2007
SOURCE:
HP LaserJet 4000 Duplexer
I realize when I say this that you will be a little skeptical but I will say it anyway . the Paper may be damp - do you notice any curling from your print if only printed on one side? this is the easiest way to test for damp paper- while the paper is damp the Electrical resistance is much higher than when its dry and this is what typically gives a Light copy however once the paper has been though the Very Hot fuser rollers to \'fix\' the first side, the paper has been force ably dried and so the second side is much Stronger in toner. try a new ream of paper and see if that helps
Jan 22, 2014 | HP LaserJet 4000 Printer
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Feb 13, 2008 | Canon PC1061 Copier
My black text is printing very light. I only use new oem toners and I don't know what to do.
Try making a copy and see if print is still light.
Try printing out a list of your settings from the machine, phone list, settings list whatever...if the list is ok and the copies are light you will need the scanner recalibrated ... you could also try changing your paper as damp paper can cause lite print.
Sep 19, 2010 | Office Equipment & Supplies
Alignment problems and color is not printing the color I want
Hello. Try to resolve the alignment problem first. That might resolve the print quality too. Here are some tips on what you can do to resolve the problem. Remove the cartridges from the printer. Close the cover of the printer without the cartridges. Unplug the printer from the power outlet. Leave it unplugged for now. Take a warm, damp paper towel. Set one ink cartridge on the paper towel like how it is placed in the printer - nozzles facing down. Drag the cartridge lightly across the paper towel in one direction (left to right) until the bottom of the cartridge looks clean. Do the same thing to the other cartridge. Plug the printer to power source. When printer asks for the cartridges, load them back in and properly secure them in its place. Close the cover. The printer may print an alignment page, just let it be. Hope this resolves your problem. Good luck!
Mar 16, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
This morning I thought I would print out some Shamrocks (for T.S. windows) on green paper. I put the green 8 1/2 x 11 in the bottom tray and asked the printer to print 5 copies. It would print 1 copy and a...
Was the green paper the type kids use in school. When my kids were little we called it contruction paper. If this is the case, your printer is smart enough to know that this paper is thicker than normal. It's responding as it should. Next time you want to print on this type of paper - select this in your printer's software control panel.
Feb 26, 2010 | Office Equipment & Supplies
I'm gettting a paper jam every time I try to print. Basically it's printing on the paper but it's jamming right behind the printer cartidge and not feeding up through the back of the printer and out.
Try the following
  1. clean the rollers with a damp cloth not wet just damp.
  2. then check all rollers in your printer for damage
  3. check that there is no paper jammed !!
Try above, if not any use try unstalling your printer and install again or trun Off and leave to reset,.
Oct 29, 2009 | HP LaserJet 4 plus Printer
Removed paper jam and now copies are blank.
Drum Memory
Make about 5 to 10 prints; then, leave the machine in the office environment (normal temperature/humidity conditions)
* This symptom is noticeable in a low temperature/ humidity environment, and is absent under normal environmental conditions.
* This symptom occurs in keeping with the primary charging roller rotation (38 mm).
Sep 13, 2009 | Canon imageCLASS D780 All-In-One Laser...
"Jammed" message
Try new paper.Damp paper causes all kinds of jamming prob.
Jul 13, 2008 | Copystar CS-2030 Copier
Contents alignment on printed/copied paper
I would recommend a good cleaning of the rollers with a damp rag (old t-shirts are great for this). Some canned air to blow out the insides always seems to improve operation.
If this is helpful to you, would you please rate this solution? Thanks!
Oct 16, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
Print quality issues
Hi slytek the usual problem is damp paper do a copy and put the same sheet back through if the problem has gone then your paper is damp hope this helps regards Dr Bob1(uk)
Feb 10, 2007 | Sharp AL 1631 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
80 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
