Question about KitchenAid KESC300 Electric Kitchen Range
Oven not working
The oven stopped working , The display says Err stuck key. F2EO.
  • Anonymous Nov 13, 2007
    I came home to find the oven stating "Err F2 E0 stuck key". It had not been used today, just the hob about 2 hours earlier. I'm not sure of it's model no. but is one of these: KGRA806, KGRK806 or KGSA906. None of the keys function.
  • 725 Answers
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Posted on Sep 05, 2007
SOURCE:
Display says err button stuck F2EO
Very vague does this oven have a keypad and a separate control or all in one if separate change the keypad
Apr 03, 2015 | Kitchen Ranges
Err codeF2EO Stuck Key onContol panel touch pad
Hi have a nice day
Guruood Luck !!!!!!
Feb 16, 2008 | Kitchen Ranges
Hi OldTech, Whirlpool Acubake electric oven stopped working after it suddenly displayed a flashing F2EO error message accompanied by a persistent beep. I unplugged and plugged it again. Thought it...
Hi
F2-E0 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 21, 2011 | Ovens
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
"F1" DISPLAYED AND BEEPING
hi there,
the F1 code usually means that you have a key stuck on the keypad. unplugging it from power won't make a difference for this one. is it a wall oven or a stove? can you supply the make & model please?
Oct 03, 2008 | Ovens
Error
f2eo stuck key sign
Mar 26, 2008 | KitchenAid Kitchen Ranges
Kitchen Aid Gas Range, Model KGR 1801
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Mar 20, 2008 | Kitchen Ranges
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
KitchenAid KESC300 Electric Kitchen Range Logo
745 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
