FixYa.com
Tags:
Sony SLV-D360P DVD Player / VCR Combo
Recording from DVR to Cassette using this?
posted by aabbay02 on Sep 05, 2007
How do I record cassette tapes from my DVR? What cords do I need?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 05, 2007
Thanks for Trying (70)
Silverdragon
Rank:Wiz Wiz
Rating: 82%, 705 votes
Well, generally, you simply need a Cable of the RCA 3way A/V cable variety, usually with Red, Yellow & White RCA plugs on the end... there should be corresponding RCA Sockets on each machine.. Plug the leads in colour to colour, then insert tape in VCR and select the Auxiliary Input (Or whatever input it is actually called) to Record from... start
"Recording"
Then on the DVR start "Play" and ya should be all up & running.
What I do first, is set it up on my TV first, using the RCA sockets, set it up so it is all playing clear picture etc.. then I connect up to the VCR.
NB: There are "Other" types of "Inputs & Outputs" among them ones called "Composite Video" "S-VHS" "SCART" ALL of these have standard interconnect leads, so if on your machine you DO NOT have the RCA Sockets.. but have one of those "Other" simply procure a Male to Male Cable of that type & then simply substitute the alternate "Cable" for the "RCA" & the rest is the same.
Rating Locked! (?) aabbay02 has rated this solution as Thanks for Trying
Can you Help with these DVD Players problems?
Unlocking region Codes
Hi - do you have a code to... Answer This...
Sony VCR
Cannot record one channel on... Answer This...
cable to connect VCR to...
Hi, is there such esy solution?... Answer This...
programming
I have a vedeo dvd combo (sony)... Answer This...
Sound
Like the other post said... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
