The springs have come out Dell Logitech wireless mouse
There's a spring (the circle in the middle with two ends) and and another one that has a circle at the top,bent into a triangle half way in the middle then goes behind and has a cquare type tip. But these have come out of the mouse and the mouse will not work.Dp/N:0T0179 RATING:3.0V=100mA S/N: LZA52652650 ______ NOM _____ 166 FCC ID: JNZ211651 CE 0560
  • nwerle Dec 22, 2007
    same was cleaning wheel
  • Anonymous Sep 10, 2008
    i have same problem
Springs came out. anyone have a description of how to re-assemble.
Posted on Oct 16, 2008
SOURCE:
How do I change the battery. Too the AAA out but neglected to pay attention on how to put them back in
It may need a magnifying glass to see, but the inside of the case where the batteries go will tell you which way to put them in.
Here are the clues:
The positive end of the battery has a "bump" or a bulge on it.
The negative end is flat, but usually has a round tiny indentation, like a circle.
Inside the battery holder you should see perhaps the picture of a battery, that is in the correct position.
Or, perhaps you will see a " + " which is positive, or a " - " which is negative.
Finally, you should see a tiny coil spring, or a flat metal spring on one end and a "bump" or a tiny round piece of metal on the other.
The bump is the positive, the coil spring or the flat spring is the negative.
God bless your efforts.
Mar 06, 2018 | The Computers & Internet
Instructions on model 343 - 8909N crib from JCP. How do I turn it into a toddler bed?
Did it come with an extra sideboard that connects the end sides together after you take one side off? The mattress spring or board should be sufficient to hold the end sides together but some come with a toddler bed side rail.
Nov 29, 2016 | Baby Gear
Does the positive end or negative end go against the spring in the bottom of the mouse?
The negative end goes against the spring. just remember: the spring extends out which would be a plus,and negative goes to positive.
Dec 27, 2010 | GE Wireless Optical Mouse
My wireless mouse fell off desk and now it left clicks only when it feels like it. i took it apart and it looks like the only problem is a spring was knocked out of place. my problem is..... where does...
mcdevito75 here, Souds like that is 1 of the return springs for either the left or righ button (click) functions on your mouse, look under the cover itself for some sort of seat for this spring,
Jul 03, 2010 | Dell U0636 Mouse
Dell wireless interfering with logitech wireless
hi
just go to control pannel , select bluetoth option , paur your dell device with the system you want to work and it will work fine.
Apr 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
MOUSE CAME APART INCLUDING SPRINGS HOW DO I PUT IT BACK TOGETHER
The Spring goes on the right side of the mouse wheel as it would be pointing at your computer. It supports the wheel to make it spring back when preasure is applied. Place the spring on the axle with the spring forming an spread out "A" (not a "V"). You will see that it falls nicely into the 2 little tower mounts. my real problem was with the other little piece of bent wire that fell out. This is the part that makes the snaping fealing as you scroll the wheel. This connects directly on the plastic part that is mounted on the scroll wheel. If you look at that plastic part you will see a small hole. One end goes in that hole & the other rounded end goes to the splines on the wheel itself. I hope this helps, it better that just saying go buy another.
Allen
Sep 19, 2009 | Dell OPTICAL MOUSE SILVER BLACK WITH...
Mouse not working correctly
Your batteries could be getting low or your reciever could be too far away.
Jun 01, 2009 | Logitech Wireless Access Duo Optical...
Bracket and spring location to reassemble mouse
just buy new mouse, usb or wireless
for $8
or just use it.
2 choices.
10000s of mouse designs there are, good luck finding that level of information.
Nov 13, 2017 | HP Wireless Optical Mouse
Spring
the spring with the loop in the midel gose on the right of the weel the other one whit the square bent on one side gose on the left side essy to figure out
Jan 23, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
706 people viewed this question
Ekse
Alun Cox
