Question about Hoover Portapower C2094 Bagged Canister Vacuum
Hoover Canister Pulled Vacuum Cleaner
I need a new bottom ( the piece that you push on the carpet) b/c the little stem, that attaches to the hose, broke. I've glued it, but it won't stay- I need a new-whatever that piece is called at the end of the hose-with the wheels.
  • 625 Answers
Go to thehooverstore and search for your machine. there are exploded diagrams for all hoover machines with parts lists and prices.
Posted on Sep 22, 2007
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Tip
Bissell Bagless Upright Vacuum not working
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Mar 21, 2010 | Vacuums
Why is water pouring out the bottom when I try to use upholstery attachment?
On many hoover models the hose attaches to the vacuum and is held on by a clip on the hose assembly. There may be some damage to your hose or the place where it attaches to the machine. Inspect these areas trying to locate the point of the leak.
Feb 25, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Water does not come out when button is pushed
Check these items:
(1) When the trigger is pulled, does the rubber pad behind the tank seal on the handle get pressed down? A rod in the upper handle presses this rubber valve to dispense water/soap.
(2) Are any hoses kinked closed at the bottom pivot point of the lower handle, where attached to base?
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Oct 11, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Won't spray
This could be caused by several things. First take the clean water tank off of the machine, and turn it upside down to inspect the bottom of the tank. There should be a gasket with a spring and valve stem, which you should be able to move the valve stem up into the tank when pushed upwards. If you notice that there is no gasket, or vale stem, you'll need to purchase a new clean solution tank.
If the valve stem and gasket are ok, then it is most likely going to the pump assembly that has gone bad. This is a little more difficult repair, you should probably look up your closest Hoover repair center, or independent vacuum repair store, and take it in to them to have it repaired.
Chris Jones
GoVacuum.com
Sep 28, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My Hoover will not turn on
there was probably a leak in the hose/piping near the pump in the vacuum that shorted out the motor. you will need a new motor for the vacuum. you will also need a new pump assembly. i strongly recommend that you also replace all the internal tubing and places where the pipes join.
Aug 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
Jul 30, 2008 | Kenmore 22812 Bagged Canister Vacuum
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Portapower C2094 Bagged Canister Vacuum Logo
116 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
