Question about Carlton HES-40 4,500-BTU ELECTRIC STOVE Heater
Replacement part I need to replace the on/off switch. Part # 10001393. Help!
    Problem Solver:
  • 12 Answers
Re: replacement part
I ordered this ON/OFF Switch and had it within a few days and it didnt even cost me 10 dollars
Posted on Sep 23, 2013
  • 3 Answers
I have found that part for you.. Just go to and if you have any questions feel free to call them at 888-634-4289
Posted on Apr 15, 2013
Posted on Nov 16, 2008
Try and use their search for a rocker switch. Then scan down to lighted rocker switch. The size and connections on it appear to work
Posted on Nov 30, 2007
0 characters
3 Points
4 red blinks, open limit switch. Replaced limit switch, still getting red blinks.
your ventor motor has to come on first to close limit switch,follow tubing from switch to ventor motor see iffu have 120 volts going to it, if 120 volts replace ventor motor assembley, no reset on board, board will reset every time u turn of power and back on
Dec 30, 2015 | Heaters
Need help troubleshooting PLEASE
Restart the unit, jump the 2 wires to pressure switch as soon as the inducer came on, if it stay on replace pressure switch. if it cut off again it should read different code which is locked out. You can call me I will help you walk through 9015501503
Jan 25, 2014 | Heaters
Replaced igniter--furnace still wont lite--need help wiring new circuit board
what is it doing,it could be anything,it might be a roll out switch or spill switch,sometimes the inducer motor is weak and not pulling in the pressure switch,is there a code flashing on the board?
Mar 24, 2010 | Heaters
How do I replace a delonghi typ 3107 dual rocker
Remove one phillips head screw that is located approximately 4 inches above the switch you are about to replace. The complete face of the heater can now be removed, then compress the four tabs on the back side of the switch to remove the switch through the cover.
Dec 02, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
My Lennox G10R03-110-1 heat unit, will not light the burners even though the pilot light is lit, and the thermocoupler was just replaced today
You have a pretty old Lennox there. The G-10's went out of production many years ago....
Since you have pilot and the thermocouple was replaced you will need to check and see if there is voltage going to the gas valve. You should have 24v AC across the two wires on the gas valve when there is a call for heat. If not then the limit switch or the high limit switch are cutting the power to the gas valve. You will need to reset or replace them.
If you have power to the gas valve then you have a
faulty gas valve and will need to replace that.
It if very possible that the gas valve has failed on a furnace the age of yours. That would be my first guess. But do check for voltage before replacing it.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Nov 29, 2009 | Heaters
Need help with a goodman gmt070 furnace...error code flashes three times, i have replaced pressure switch, still flashed, replaced board, still flashes three times...flue is clear, draft inducer motor is...
it may be clogged at the barbed fitting on the induced draft motor where the pressuer switch tubing connects. take a paper clip and **** it out make sure you can stick it thru freely till you can feel the Inducer wheel then reconnect and try again.
Nov 04, 2009 | Heaters
The 900w on/off switch does not work. any
You can go to the radio shack and purchase a universal switch to replace it.As long as the replacement switch will hold 900 watts or more(125volts)it will work.Take the switch with you.Replacement parts are almost impossible to find.Hopefully,this will help you.As the heaters go out,switch or thermostat,or element,I but a new one,I have been for a long time.I end up with extra parts to fix one or two,so I end up using the heaters longer than expected.Don`t buy the digital L E D versions,they won`t work right,and go out quickley. If I can help,let me know.I hope this is helpful.
Sep 29, 2009 | Lakewood Oil-Filled Electric Radiator...
Need switch fort Presto Quartz Heater
Any hardware store should have a replacement switch for you. Let me break the numbers down to help you out.
INF = Infinite switch
120 = 120 volts
887B = model number of the switch
34-191 = date code
15 amp = ampacity rating of the switch
120 vac = Again this is a 120 volt switch A/C
If you need anymore assistence please comment back.
May 06, 2008 | Heaters
Replace worn parts and ware to find them
You didn't give a location, so I cant offer someone to help. I do know that the magnetic switch, otherwise known as a contactor, chatters because its not getting enough voltage at the control coil. It should have a label listing the coil voltage on it, check the power source and go from there.
Mar 18, 2008 | Dayton (4LX41) Heater
Heaters Logo
477 people viewed this question
Top Carlton Heaters Experts
Dan Webster
Dan Webster
Are you a Carlton Heater Expert? Answer questions, earn points and help others
