Question about LaCie (300740) 160 GB Hard Drive
Lacie 160 gb hard drive problem
Recently my lacie external 160 gb hard drive was plugged up by usb 2.0 to a friends cpu. i hit the eject button but it said it was busy and i pulled out the usb not thinking. Now when I plug up my external hard drive on my computer or my laptop it doesnt show up. I started playing around with my device drivers on my cpu and it popped up but then failed to load. is there a way to solve this problem. can i download software?
  • Anonymous Feb 16, 2008
    My LaCie 160 GB external HD, icon failed to appear on my HD when I turned on computer one morning. It had been operating the previous day. It also disappeared from my ALL Program LIst. The light was lit on the unit which became warm. I tried disconnecting the power unit in my computer for five minutes, which was offered as a possible solution , It did not heldp. Another solution offered was to change the housing of the computer HD. but I do not think the cause likes there, as I have two computers and neither recognizes it .
  • darvsin Nov 22, 2008
    none of the computers are recognising my Lacie 160 GB External hard disk now.. Yesterday it was working perfectly... Donno what went wrong suddenly.
  • 3 Answers
Did you mess with any Config Files?
Posted on Sep 13, 2007
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
Cannot turn on
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
hope this helps
Aug 22, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have 2 lacie external hard drives that no longer work. They power up and I can hear it working, but they are not reconized on any computer.
Chances are, the IDE/SATA to USB/Firewire controller inside the device has died. You can take the case apart and take the hard drive out, and plug it directly into a computer through IDE or SATA, whichever it is. If the drive is recognized, then all you need is another external case to put the drive into. If it isn't recognized then most likely the powerboard on the hard drive or some other internal mechanical part is dead, and you would need professional data recovery to get anything off of it that you would want.
Apr 30, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
How can I open a LaCie B350 External Hard Drive?
You can carefully pry the bottom off with a screwdriver and remove the drive.  No problem using a "USB to IDE/SATA cable" ( Here's the first hit on Google:  Worth $20. ) to copy off your data.  Or you could mount in your desktop PC.
Jun 26, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
First time trying and i cannot access my data. This is the first time I tried to pull it up.
USB is very finnicky. Shut off your computer and external drive. Unplug the USB cord from one end (which ever is easiest). Turn on your computer. When windows is up, plug in USB cable. Turn on USB drive. Windows should recognize the USB ox and drive and attach the extra drives. But, you must have windows millenium or newer. Or you will need USB drivers for the external USB box.
May 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB not showing on MacBook Pro
The first thing that I would do is try connecting the drive to different USB Ports. If that does not work see if there is any software that came with the drive or that you can download from the internet that you might need to get the drive working. Next I would connect it to a different computer to see if it works that way. If it works when connected to a different computer I would at least get the files on to that computer and transfer them to the computer that you need them on using a network connection, a CD/DVD, or a USB thumb drive.
Nov 07, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
411 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
