Question about Ovens
Dacor convection oven cps127/130 failure code f1
Book says code f1 means element relay circut failure, does this mean i must replace the main relay circut board?? thanks, steve
  • 3 more comments
  • peggy320 Sep 17, 2008
    oven kept beeping, could not stop it last time - I pulled the fuse - prior it had been working OK and now and then erratic beeping
  • lynnwhite Nov 01, 2008
    With no warning, display blank, buttons do nothing. Cooktop igniter and oven light work. I understand this may be due to bad relay unit. Not sure yet if that part can be fixed or must be replaced. This failure has happened twice to a poster on another repair site.
  • richardjones Nov 04, 2008
    error FI and the unti beeps and cannot be cleared.
    It is one of three things, the ERC pcb, the relay board or a fault with the membrance switch.
    All expensive so how do I identify the problem child?
    Thanks
  • Anonymous Mar 17, 2014
    dacor f1 oven
  • Anonymous Mar 22, 2014
    f1 alert on board
I found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
Posted on Sep 05, 2007
SOURCE:
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
May 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
What does the F1 mean
Hi, the F1 error code means a problem with the System Watchdog Circuit..
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Nov 16, 2010 | Dacor ECS127 Epicure Electric Single Oven
I have a Dacor ECS130 and when we turn it off the F1 code comes up and it beeps forever. i tried uplugging the membrane switch from the control/clock module (with the power off) and there is no F1...
Hi
Thanks for using FixYa. Error F1 in your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Ovens
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor touchpad
HI, this is a Element relay circuit failure. this relay is a separate PCB board with attached relays.
this relay board will need to be replaced.
CLICK HERE TO ORDER
Jul 19, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Dec 04, 2007 | Ovens
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
1,147 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
