Question about Sony KP61XBR200 TV
57H81 I can't fix the converge on my tv it doesn't work at all please help
    Problem Solver:
  • 8 Answers
Yeah common problem with the convergence cir get a tech to fix your converg 2 ics will be replaced it is labor time consuming now dont try the auto focus or will be worse
Posted on May 10, 2008
I finally got my tv hooked up. but the color and the picture is blurry, mostly on the top. i have tried different things but no matter what it doesn't change the blurriness,and some lines come across...
Tv have a R,G,B colors lines misalignment,have picture shadows or 3D picture look alike?Yes,than tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair,by replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 13, 2011 | Toshiba 57H81 57" Rear Projection...
I have a Toshiba 57H81 57 in. Rear Projection Television. The picture started having "squiggles" in it, which at first went away after the T.V. "warmed up". Now they appear to be...
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replace on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Toshiba 57H81 57" Rear Projection...
My toshiba 57h81 tv is showing up double vision, looking like the red is off and not aligned. Also the touch focus in the menu says error whenever i try to touch focus it.
This tv have a problems known as a Convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.This parts must be replaced to solved the convergence board problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Toshiba 57H81 57" Rear Projection...
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
I have a toshiba big screen tv we believe both convergents need to be replaced we do not have 300-365.00 to repair it . I know how to solder can I do it myself???? model#57H81
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Toshiba 57H81 57" Rear Projection...
I'm having a problem with my Toshiba 57H81 Rear Projection TV where there is to much green in the picture. Adjusting the tint and colors only helps some. I notice when I turn the TV off rather than a ...
Two things---first if you don't mind give me a vote here--I am rated on how many problems I fix
Second---with the original remote go into the customer menu and select Convergence---see if you can adjust the other problem that way---I can if that helps you email you the instructions for going to the tech menu to adjust convergence all over the screen and and saving those adjustments----if you find the convergence will NOT adjust in some area of the screen you may have a convergence problem.
I would appreciate a vote here for my help and if you need the directions for the advanced convergence let me have your email.
REGARDS, SD TECH
Sep 20, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba Rear Projection Tv 40WH08B
If the convergence on one or more color does not align using the convergence setup procedure, that means that one or more convergence ICs must be replaced, that is the reason why you get bad picture.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 10, 2009 | Toshiba 57H81 57" Rear Projection...
Convergence problem with a Toshiba 57h81
you need to replace both convergence ICs. they are both STK392-110 ICs you can get replacements at the following link with free instalation instructions with pictures so you can do the repair yourself. here is the link.
http://servicemanuals.vstore.ca/
Jul 26, 2008 | Toshiba 57H81 57" Rear Projection...
I have a 57h81 no picture no sound red blinking light
dont have the board number but it's the one with the silver heatsinks
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 07, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81
Go to the convergence and align the red and blue + - Under Menu then Picture then convergence to get to this screen- Hope it helps
Mar 24, 2007 | Toshiba 57H81 57" Rear Projection...
Sony KP61XBR200 TV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
