Question about Sony Xplod XM-1652Z Car Audio Amplifier
No Power to the Amp
I was driving to town the other day on a dirt road and my bass suddenly went out. I stopped and checked my amp to find out that there was no power going into it. I got home later and redid the wiring to the amp and even tested the wires to make sure they had power, but still no power to my amp. Any ideas? The amp isn't even 7 months old yet but I made the mistake of throwing away the box and receipt.
    New Friend:
My car battery got battery got power but my amp not coming on noore
Posted on Jan 17, 2015
  • 883 Answers
Open the amp and look for a fuse either on a circuit board or on wires inside. trace power wires onto board.
Posted on Sep 05, 2007
My and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
Dec 16, 2015 | 2004 Chrysler Town and Country
Infinity 336rms amp worked for over a year then one day stopped?
check your fuses. Also check the power wire connection to the amp and then the ground source maybe move that if there is paint under it. check fuses on the amp. Check ohm load to the amp from the speakers.
May 27, 2009 | Infinity Reference 611a Car Audio...
Amp goes into protection
First change the wire,and disconnect the subwoofers to check if the amplifier turn on without going in to protection mode,if the amplifier go to protection mode you gotta change the Audio amplifiers IC's because they are in short circuit.And if don't go in to protection put one speaker at a time to check if one of them are damaged.Good luck.
Jun 02, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Clipping amp
hi first disconnect all spks, then turn on the amp. if amp power lite stays on bright then proceed to connect one speaker or sub to the amp. if the amp lite dims during any spk connections then it may be that the spk is faulty or there is a DC voltage (dc offset) emitting thru that particular channel. also check all spk impedance before reconnecting them to the amp. cheers.
Aug 04, 2007 | Alphasonik PMA600HC Car Audio Amplifier
Subwoofers unresponsive
Check the physical condition of subwoofer to make sure that the surround has not rotted out or been blown away. If ok, then using an ohm meter check for the nominal speaker voice coil resistance to make sure it is within spec. If both of these areas are good then you have destroyed the output stages of the amp(s) driving them. Every 3 db of bass boost doubles the output power. So if you are blasting along at 100 watts and you jack up bass by just 3 db the amp now has to put out 200 at those lower frequencies; go up by just 6 db and you are now talking 400 watts! And what does that do to an amp when you over drive it? You guessed it!
Aug 27, 2017 | JVC MX-G50 CD Shelf System
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
149 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
