Question about Dell E171FPb 17" Flat Panel LCD Monitor
Dell E171FPb monitor turns on, but that's it
When I turn my Dell E171FPb monitor on, it doesn't go to a blank screen with the no video input box. The screen shows 4 horizontal columns that have different contrast levels. The top column being black, and the bottom being white. A vertical column that is brighter than the horizontal columns scrolls from the left side of the screen everytime you turn it on, and once it hits the right side, begins scrolling back to the left again.
  • 103 Answers
Re: Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Posted on Jan 30, 2008
0 characters
3 Points
I want to use the Dell E171FPb 17" Monitor as a TV. How do I do it. It does not have RCA, or S-video jacks.
Hi friend,
You can purchase TV tuner card then you can use as TV. There is not other option for you....
Jan 05, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
White horizontal lines on entire screen
I’ve never seen this kind of video output caused by a bad video cable or bad FL inverter board. laptop was fixed after I replaced the LCD screen.
Apr 03, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
E172FPb Flat Panel Color Monitor black screen problem
Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at:
I hope this helps, If so please rate my solution.
Corporate Computer
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Powers up, shows test menu then black screen
This sounds like a video problem with the COMPUTER.....try the monitor on another computer. Usually, if you can see the monitor test pattern the monitor is ok.
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
You can buy a new 19 for about the same price
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell e171fpb lcd monitor
The driver tabs between the LCD panel and it's controller board have failed.
These are very fragile and not repairable for anything in the cost effective range.
Best option is to either find a new panel to replace it, or get a new monitor.
Sep 10, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FPb 17" Flat Panel LCD Monitor Logo
293 people viewed this question
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
