Convergence green lines
posted by atlasbrooks on Sep 04, 2007
I have a jvc 48" HD (av-48wp34). There are several wavy green lines across the top of the screen. I understand this is normally bad ICs; I have 2 392-150s on order. I saw no burnt resistors on the board.
Is there anything else I need to look at; I would hate to plug it in and blow out new ICs.
Comment posted on Sep 05, 2007
Sounds good, I will check it out. I have an OHM meter so I can check for correct readings.
I was also told I need to check the voltage going to the convergence board. Does that sound right? If so, what should the voltage be.
Thanks
Comment posted on Sep 08, 2007
I appreciate your help; Please excuse my ignorance.
It looks like there are 2 candidates on the convergence board for power. The most likely is a 3 pin block that plugs in directly under the power button (I assume that is the power supply board); it has 2 gray wires and an orange on the end. Voltage on both ends is 8.4.
The only other candidate on the conv board is a 10 pin, gray with a black on one end. It has a couple of pins with 34.2v and one with 29.2.
Also I saw 2 plugs on the little board behind the convergence board (with the crossover plugs to main board). I did not check those, as they are not attached to the conv assembly.
Also, the screen looked competely different with out the convergence board plugged in, I assume that means it was doing something,so there had to be power there.
Am I on the right track here? If this is not correct where are the fuses/resistors for the conv power supply located.
Thanks again.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 04, 2007
Helpful (85)
QTV1
Rank:Guru Guru
Rating: 90%, 104 votes
Closely inspect the board for poor solder connections. Also someitmes the resistors will not show any signs of being bad even though they are open. It is wise to measure them but you need to disconnect the convergence yoke plugs to ge a good reading.
You should have approximately a +25v source and a -25v source. If one of these is missing you will have a fuse blown.
Rating Locked! (?) atlasbrooks has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on convergence green lines:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
it makes a thumping noise and wont turn on
I don't have a picture or sound, it shuts down too...
Video is all green and squeezed together on the top half...
The picture size on my tv screen is 4 inches smaller on...
my jvc av-48wp30 powers on but no sound or picture.. had...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
TVs
TVRepairman.com is committed to helping you local...
TV RepairMan
(800) 575-9833
TV Parts for All Major Brands Genuine Japanese...
Acme Enterprises
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
