Question about Amana AFB2534DE Bottom Freezer French Door Refrigerator
Maytag mbf2258hew replace jazz board
Wondering if you can help me replace a jazz board for maytag mbf2258hew refridgerator
    President:
  • 878 Answers
Bug, the jazz board is pretty easy to replace. The light cover will slide off toward the back. Now if you look behind the control panel you will see two slots. Take a flat blade screw driver and push the cover tabs in while pulling down on the cover. The cover will come down. Two slats slide in on the front and will release, disconnect the harnesses and install the new board. Reverse the process. Catriver.
Posted on Sep 04, 2007
  • Randall
    Randall Dec 29, 2013
    I have received an new Jazz control board (part number 16022940) for my Maytag fridge model GC2225PEKS and the code on the label in the fridge is not accepted.
  • 64 Answers
The replacement board should come with instructions to program the code number ftom the mod/ser# tag on to the new board. it wont work till programed
Posted on Aug 26, 2009
  • denton gregory Aug 30, 2012
    any have a copy of the instructions sheet? My replacement board is not working well and occasionally fails to turn the compressor off. Quality contractors on these boards.
    Champion:
  • 323 Answers
The programming "how to" info is usually included with the new board. Your refrigerator operating code number will be listed on the model/serial number tag as CODE and is a two digit number. Follow the programming steps very carefully and you shouldn't have any problems. If at first you don't succeed . . . .
Posted on Apr 15, 2015
My refridgerator section doesn't get over 56 degrees. I think the freezer below is the only thing cooling.what could be wrong?
You are most likely
completely FROSTED up...
Stops air circulation and a limited space in the IMMEDIATE are of your EVAPORATOR COIL acts like an old fashion ICE BOX...
I just finished an exact duplicate of a Kenmore
bottom refrig... (ditto Maytag, Amana & Whirlpool).
Issues are very much the same... I would love to help.
(or you can pull down some of my recent ANSWERS).
Go on-site...Including a VIDEO how to on the DEFROST CONTROLLER... Watch it...
Comment your model number back to me & I'll look for you.
Easy DO IT YOURSELF job...
EXACT Price depend on the make/model
Check out the VIDEO (below... )
((some body else's part... Need your MODEL Number)).
http://www.appliancepartspros.com/whirlpool-board-jazz-wpw10503278-ap6022400.html
Apr 19, 2017 | Refrigerators
Light for water dispenser is on and flap keeps opening and closing. No Water, just flapping sound and sound like motor running. Can only be stopped by cutting power to unit. How to fix??????
you have a bad main control board. ( called the jazz board .. ) it will have to be leplace to correct problem .. mm hope this helps feed back pls ..
Jul 10, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Maytag gz2626gekb side by side and the damper door seems to get stuck due to chips of ice forming around it. It jams on the chips of ice. Ive replaced the damper assy already and still experience...
If your air damper door is constantly getting ice forming on it there is a reson for this. This is most oftern caused by an improperly sealed fresh food compartment door gasket, a warped door or improperly adjusted door hinges. Having said that... there can be other causes such as a clogged compartment drain in eaither compartment that forces air to rapidy transfer from one compartment to the other side when one of the doors is opened and the rapid temperature change initiates the rapid air flow and eventual condensation / freezing.
Make sure your compartment drains are clear and the end of the drain tube that terminates in the catch basin under the unit is free of obstructions. (rear fiberboard compressor cover removal required) To cause the rapid air transfer I spoke of above this tube has to be blocked.
If you discover that the compartment drain is clogged with ice.... the only fix / remedy is to perform a manual defrost by unplugging the unit, removing the freezer contents and directing an exteranl fan into the freezer compartment for just over 2 hours. The reason for the 2 hours is that should there be ice in the drain funnel the water in the top of the funnel accumulates on top of the ice and insualtes the ice in the funnel from melting so you just have to wait until it warms up over time.
After perforning this manual defrost... use a vacuum to first attemot to remove any debris from the drain tube end and then put the hose on exhaust and direct air into the end of the compartment drain tube to float out any debris from the compartment drain funnel.
One question I have is why are you changing Jazz boards? Do you suspect you have an Automatic defrosting problem?
Thanks for choosing FixYa,
Kelly
Mar 26, 2011 | Maytag Refrigerators
Control panel not lighting up
this maytag may have a main board failure this board is called the jazz board . replace it and i think it will correct problem. board comes with instructions . to complete job .. hope this helps mm
Oct 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Temp control is flashing and clicking
you will have to have the jazz board replaced . very common problem . i have one in my own home . . this is the main control. and the only correction . A Maytag problem .. new boards have been revised and do not have the problem .. **** ,. have been doing maytag since 1950 's // hope this hepl.s if your do this service your self ( read the instructions good . as when your finish you wll have to program the control for your model .. **** . .its a easy job but you have to finish it properly.. mm
Jan 06, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag PBF 2255 HEW refrigerator JAZZ board replacement issue
thats different I was thinking of something else the board you are talking about just controls the temp. controls this may be your problem call1-800-688-9900 maytag or 1-800-253-1301 whirlpool they can give you a better idea on the part number issue this may be the problem
Jan 10, 2009 | Maytag Refrigerators
All lights on front digital are flashing.
your right. the main board which is on the back of the frig needs to be replaced. not hard to do, just follow the instructions that come in the box to reset the code
Dec 06, 2007 | Refrigerators
My admiral fridge freezer suddenly stopped working -
I took the time to look up your Model # and you do have the right board. Jazz 14 Should just be a revision one higher than your origional. Describe to me exactly what happens when you try to program it. You may be missing one little step. Make sure you are doing every step exactly right. I too can miss one little confirmation stroke and it seems like it wont work. I Can email you the tech sheet for your model. This will show you how to test all the sensors, and the damper to determine why the FF side is getting too cold. I will also help on my end as much as i can
Nov 25, 2007 | Frigidaire FRS26R4C Side by Side...
Amana AFB2534DE Bottom Freezer French Door Refrigerator Logo
2,136 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
