Loud humming coming from subwoofer
I just moved and the system worked perfectly before it was disconnected now as soon as I plug the power cord into the sub it starts a loud humming. gets a little quieter as soon as I plug in the satillite speakers but is still there even though it is not even hooked up to the computer. I reinstalled the drivers in my computer for sound (headphones work fine) Sounds like they are getting to mush power???? Clueless..... Boston Acoustics Gateway Digital BA735 Speakers With Subwoofer
  • 7 more comments
  • zach20 Dec 04, 2007
    my mom did a recovery on my computer and now my speckers are huming
  • Anonymous Nov 22, 2008
    humkming noise but everything hooked up rite
  • Anonymous Jan 05, 2009
    But, with knowledge of electronics, I believe the problem is in the board in the bass speaker. To be more precise, it is most likely the big capacitor next to the diode brige rectifier(c59). I'll know for sure when I get a new capacitor. I do however wish I had a Schematic for this board.
    Thanks,
    John
  • Anonymous Jan 09, 2009
    speakers
  • itsawhoa Feb 08, 2009
    I have same problem. Hum is not from external source seems to be something amiss in the electronics inside the sub cabinet. How would I indentify the Capacitor that was mentioned in the other post.
  • kansasbarn Feb 16, 2009
  • kansasbarn Feb 23, 2009
    I have the same problem. I moved the subwoofer away from the cable clutter and that reduced the humming but it did not eliminate it completely.
    I have the same problem. I moved the subwoofer away from the cableclutter and that reduced the humming but it did not eliminate itcompletely.
  • raisingkane Mar 04, 2009
    I have the same humming coming from my sub and satellites. I have checked my power supply and video card, but by just powering up the sub/speakers and the humming starts. It just happened all of the sudden. An earlier thread mentioned replacing the C59 capacitor for the fix. Does this fix the problem? What is the value of the cap and where did you buy it from?
    Scholar:
  • 41 Answers
This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
Posted on Sep 04, 2007
The hum problem can be fixed in two ways.
First unscrew the 18 screws and fold out the heat-sink back-panel. Look inside towards the right and you see the ring-transformer.
Using a 14mm wrench-key you can either(1) tightened the loose bolt or(2) completely remove the transformer and with tie-wraps fix it to the rear side of the wooden triangle. Put some foam-plastic cushion around the transformer, isolating its vibrations from the box.
I now have one pretty silent(1) and one completely silent(2) bass units.
Posted on Sep 13, 2009
  • 112 Answers
Check for improper connection or no ground like a jack thats only half in or wires reversed.
My powered sub is humming
Does the humming go away if the cable is plugged in but you wiggle it? May be a bad connection on the input jack.
Mar 22, 2013 | Klipsch Audio Players & Recorders
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
Major hummimng noise when sub is connected to receiver.
Is the hum in the receiver-attached speakers or the sub?
Self-powered sub?
How is the sub attached - RCA or speaker-level?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
If it hums with the sub attached, unplug the sub's power cord. Differences in AC ground potentials will generate hum across linked devices.
Mar 25, 2011 | Yamaha RX-Z9 Receiver
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
Making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
Apr 08, 2010 | Velodyne CT-100 Speaker
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
2,297 people viewed this question
 Grubhead
Grubhead
