Question about Canon CLC 1150 Color Copier
Inconsistent color after only a few prints
Usually when I first start the machine up, I don't have problems. But after to a few prints I begin to get bands of lighter areas. The strips of less colour are sporadic, and I am not sure if it is a driver issue, my files or if I need new consumables. I don't know much about my machine, but I don't want to pay a tech to look at it. Someone please lend me a hand. Thanks
Thanks for responding. I had it serviced today, and it didn't correct the problem, but the tech mentioned that it was probably a developer problem (thought it would need to be changed) though he didn't calibrate it to my knowledge. I am not going to put any more money into the machine and I am resigned to the fact that I will just have live with the inconsistent output. I have found that if I send two copies at a time I am usually okay. If I send 50 or so, then I am getting a bad copy every other page. Thanks again for responding.
Posted on Sep 07, 2007
  • 163 Answers
It sounds most likely that there is a developer/toner calibration problem. I know it is very expensive but when was the last time you had the machine serviced?
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    How do I clean my Brother MFC 210C. I've done it before ont eh computer, but can't find where to do it this time.
    Press the Ink or Ink Management key on the control panel of the machine. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set. Press Color (Colour) Start. The machine begins printing the Print Quality Test Sheet. By reviewing this Test Sheet, you can determine if the print quality needs improvement. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    The display will then show START CLEANING? 1.YES 2. NO. Press 1 (YES) and the machine will start cleaning the color ink cartridges.
    Jan 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
    ESP9 color prints begin coming out purple like
    Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
    Jan 02, 2010 | Office Equipment & Supplies
    Its printing patchy and ghosting
    it will yes. I know with fusers and xerox you can usually reset the fuser. When servicing the machine the techy will do this for you:)
    Nov 18, 2009 | Xerox Phaser 7400DN Laser Printer
    Spotty color print
    first of all you can remove your color cartage
    and check this cartage to simple page
    which color is appers
    after that refill the cartage from the serge
    3ml
    3 color in the cartage and every color every point you can refil
    Sep 20, 2009 | Alps MD 1000 Thermal Printer
    Inconsistent color, nozzles clean same ink cartridge same paper
    Problem with ink continuity. Ink at head spray out, but ink at tank not flow to head. Print block color for each color. Is it perfect? Do nozzle check, head cleaning, wait for 30 minutes. Check again.
    Aug 16, 2009 | Epson Stylus Photo 915 InkJet Printer
    Verical lines of inconsistent or un-even printing,
    In almost every case, the problem you describe can be traced back to 2 things. Dirty corona wire or dirty drum (or both). Pull out the toner cartridge, slide the wire cleaner back and forth a few times, clean the drum. The gently shake the toner cartridge from side to side to evenly distribute the toner and replace. This should solve your problem. Best of luck.
    Greg
    Jun 21, 2009 | Panasonic KX-FL501 Plain Paper Laser Fax
    Unable to print BLACK
    The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
      1. Press the Ink Management key.
      2. Use the up or down navigation key to select TEST PRINT.
      3. Press Set to confirm your choice.
      4. Use the up or down navigation key to select PRINT QUALITY.
      5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
    If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
    Cleaning the Print Head
    2. Use the up or down navigation key to select CLEANING.
    4. Use the up or down navigation key to select the color that is not printing
      -OR-
      Select ALL if more than one color is not printing.
    5. Press Set to confirm you choice.
    6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
    7. Test by printing the "Print Quality Check Sheet":
    If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
    I hope it helps!!!
    Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
    Canon CLC 1150 Color Copier Logo
    51 people viewed this question
    old marine
    old marine
