Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer problem my printer is signaling "check printer then hit ok". a few days ago I had some paper jamming, i cleared it out then hit ok - well it hasn't been the same since
    Problem Solver:
  • 13 Answers
Did the paper jam clear completely? Look for a small piece of paper stuck somewher inside the paperfeed track that's setting off the sensor. Clear that and you should be fine
Posted on Sep 24, 2007
SOURCE:
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    2575 paper jam
    You could try gently shaking it and see if anything falls out.
    You should also try cleaning it, first maybe with some compressed air, you may have a dirty sensor or something
    Another thing you should try is unplugging it and allowing it to reset.
    Please let me know how the above work out and I can give you further options to try if none of them work.
    Thank you for using Fixya and Have a Great Day!
    Apr 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
    I had a paper jam a few days ago. Turned printer off then cleared jam and when I turned it on again it still had the E3 error code indicating it is still jammed. There is no paper in it anywhere. I have...
    Check the paper feed tray for bent papers. Also, try blowing over the sensors to clear any debris. Check for small pieces that may have been left behind. If all fails, unplug it from the outlet, then start it up. Good luck!
    May 06, 2017 | Xerox WorkCentre XE90FX Laser Printer
    Paper jam cleared no tears message still appearing clear paper jam than pressk OK have open the printer checked thoroughly turned off 8 times and on again. No paper jams all cleared.
    When you turn off the printer unplug it from power and the computer for a few minutes. Plug only the power back in and turn it on. Also consult the manual to find out how to "reset" your printer.
    Hope this helps
    Mar 08, 2011 | HP Photosmart D5360 InkJet Printer
    States paper jam when I go click to print?
    That's happened to me before on my HP printer. Try opening the printer and checking for any paper that might be jammed. Look very carefully, if you find paper that's jammed, carefully remove it. Close the printer. If you have the option to hit OK to clear the jam on the printer, do so, and then try re-printing.
    Mar 01, 2011 | HP Office Equipment & Supplies
    Jamming problem
    try this
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
    "Clear paper jam" error, but there is no jam!
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    prirweto-i-23
    Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Canon PIXMA MP780 All-In-One InkJet Printer Logo
    141 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
