Question about Technics SL-1200MK2 Turntable
Technics 1200 The platter on my 1200 lacks alot of torque. I suspect the motor may be worn as it is an old turntable. Are there any other possible reasons?. Also I have looked into motor replacements and I have been quoted 350e to replace the motor my by local dj store. How difficult is it to replace a motor?
What a load of rubbish - The deck of course does have a motor - a diect drive set of coils and a static magnet on the platter. The 'capacitors, resistors and IC's' form the circuits controlling this motor.
The problem could be a bad connection in one of the channels controlling the motor, but is unlikely to be any of the IC's.
Like the noob above says - it is repairable for around Euro100.
Posted on Oct 10, 2007
  • 515 Answers
FYI, there is no motor on these units. The only thing that makes these babies go round is various capacitors, resistors, and IC's... all which play a crucial role in control and maintaining the unit's speed. If you do not have enough torque, then the issue is probably with one of the main IC's (IC101, IC102, or IC201) - however, it could be any of the other circuits as well. A qualified technician should be able to pin point the problem and have it repaired for you. The repair on this isn't that expensive. I'm going to assume 350E is euro? If so, you might as well buy yourself a new Technics 1200 for that amount. If it is not euro, then this type of repair should cost you about $70-120 - including parts and labor. (these are the prices we charge in our NYC shop - for comparison purposes).
Posted on Sep 23, 2007
Technics sl 1200 dragging
almost often a wrong set table/arm weight and a dirty needle. . i gues the last. Cleanen record
May 13, 2014 | Technics SL-1200 Turntable
Is it bad for the motor to test a technics sl 1200 off load with the platter removed?
No. Motors simply turn. It's when you make them work harder by putting loads on when the problems start.
Aug 07, 2013 | Technics SL-1200MK2 Turntable
I have two 1210s, a mk 2 and a mk 5. When I let go of a record on my mk 2 it seems to take longer to catch speed compared to my mk 5, and feels 'slack'. Any ideas what this is?
Being the older model, the chances are that the drive belt on the Mk2 turntable has got worn and shiny with use. It may also have stretched a bit. If you are using the tables for 'scratching', the fact that you are holding onto the turntable when the motor is running is placing a strain on the belt that it is not really designed for. I would recommend changing the belt - you can easily find spare belts for sale on the internet
Feb 02, 2011 | Technics SL-1210 Turntable
How to calibrate control on a technic 1200 by sight
Put the pitch slider to +6 and adjust the internal preset until the top set of dots on the platter are stationary.
Check again with the pitch at +3.3 if the dots are stationary then job done!, if not then the pitch slider is worn and perfect calibration won't be possible until the pitch slider is replaced.
http://stores.ebay.co.uk/methleykev
Jul 14, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
Motor turns feebly, not enough to make the platter
Sounds like the motor is bad if you say it turns feebly. See if you can turn the drive shaft with your fingers easily. If you find it hard, it's possible that something might have worn out. You could try oil in that case.
Feb 02, 2010 | Pioneer PL-990 Turntable
Just bought a new technics sl-1200 turntable and the pitch speeds up and down causing music to sound funny....
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Dec 03, 2009 | Technics SL-1200 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Torque Problem
They actually need to be "broken in". The mk5 uses a different pitch board, allowing you to reverse, pitch up and down to 16, and lock and unlock the quartz. The mk5 is more precise, so its also more sensitive. Notice the notches on the turntable shaft behind the tonearm weight. The mk5  is just make to be finer calibrated.....your decks are fine, and more so probably your mk2s as well.
Oh and also, the infinite lubrication used on technics that was developed in the 70s is no match for the formula developed in the late 90s. Slick!!
Sep 30, 2007 | Technics SL-1210M5G Turntable
Technics SL-1200MK2 Turntable Logo
310 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
