Question about Fantom Drives 300 GB Hard Drive
Drive not showing up on my Mac
I am having the problem of whenever I plug my drive in, it doesn't show up al all on my Mac. When I plug the firewire in, the blue light blinks a little bit, but that's all. I it possible that the wire is defective?
  • 1 more comment
  • Kirstin Sep 08, 2007
    Ok I kinda just copied everything b/c i don't know what most of it means.
    dmesg
    standard timeslicing quantum is 10000 us
    vm_page_bootstrap: 125001 free pages
    mig_table_max_displ = 68
    IOKit Component Version 7.9:
    Wed Mar 30 20:07:52 PST 2005; root(rcbuilder):RELEASE_PPC/iokit/RELEASE
    85 prelinked modules
    Copyright (c) 1982, 1986, 1989, 1991, 1993
    The Regents of the University of California. All rights reserved.
    using 1310 buffer headers and 1310 cluster IO buffer headers
    Local FireWire GUID = 0xd93ff:0xfeb3bcb8
    ADB present:8c
    Security auditing service present
    BSM auditing present
    From path: "/pci@f4000000/ata-6@D/@0:3,\\mach_kernel", Waiting on IOPathMatchIODeviceTree:/pci@f4000000/ata-6@D/@0:3
    Got boot device = IOService:/MacRISC2PE/pci@f4000000/AppleMacRiscPCI/ata-6@D/AppleKauaiATA/ATADeviceNub@0/IOATABlockStorageDriver/IOATABlockStorageDevice/IOBlockStorageDriver/FUJITSU MHT2060AT Media/IOApplePartitionScheme/Untitled@3
    BSD root: disk0s3, major 14, minor 2
    Jettisoning kernel linker.
    Resetting IOCatalogue.
    Matching service count = 0
    AppleRS232Serial: 0 0 AppleRS232Serial::start - returning false early, Connector or machine incorrect
    UniNEnet: Ethernet address 00:0d:93:b3:bc:b8
    AirPortPCI: Ethernet address 00:0d:93:ee:36:70
    IOFireWireIP: FireWire address 00:0d:93:ff:fe:b3:bc:b8
    ATY,Via_A: vram [9c000000:02000000]
    ATY,Via_B: vram [98000000:02000000]
    AirPort: Link UP: "linksys_SES_43064" - 0014bfa624da - chan 11
    AirPort: Rx'd mesg P-1
    AirPort: Rx'd mesg P-3
    AirPort: New Group Key, Idx 1
    IP packet filtering initialized, divert enabled, rule-based forwarding enabled, default to accept, logging disabled
    IPv6 packet filtering initialized, default to accept, logging disabled
    IP firewall loaded
    AppleNMI mask NMI
    AirPort: Link DOWN
    System Sleep
    System Wake
    Wake event 0008
    AppleNMI unmask NMI
    Sound assertion "0 != err" failed in "AppleLegacyAudio/AppleTexas2Audio/AppleTexas2Audio.cpp" at line 960 goto Exit
    \^PFWOHCI handleSelfIDInt - nodeID not valid (reset bus and retry 1)
    ADB present:8c
  • jazpheen Jan 03, 2008
    Help! I have a Fanthom external drive and a iomega portable ext drive that does not show up on my screen. They both use to show up on my mac Ibook and now they don't. I used the ibook ext drive for awhile then one day it just stop showing up on the screen so I bought the Fanthom and the same thing eventually happened. My operating system is 0SX.ver. 10.3.9. I did go into the system profile and when click firewire, the Fanthom shows up when it's plugged in but still soesn't show up on the desktop.
    Any ideas? Alex
    Al FireWire Bus:
      Speed:    400 Mb/sec Speed
    BABW:
      Capacity:    111.79 GB
      Manufacturer:    DMI
      Model:    BABW
      Removable Media:    No
      Detachable Drive:    Yes
      BSD Name:    disk2
      OS9 Drivers:    No
      Unit Spec Id:    24734
      Firmware Revision:    4.73
      Unit Software Version:    10483
  • chilidani Feb 11, 2008
    i have yhe sem problem in my imac g5 powerpc 1.6
    Problem Solver:
  • 6 Answers
It's possible. Has it worked before? Does it work on other computers? If it has worked, has it worked on this computer before? Can it be connected via USB (some externals have both) and does it work that way? Can you hear the drive spinning when it's powered on? On your mac, open up a terminal (maximize the window), plug in your drive and type this in the terminal dmesg This will output a ton of stuff, but the last 20 lines or so should be relevant to the last event, namely, connecting your drive. Copy that text to here and we'll take a look at what's going on. If you're feeling adventurous, you could take it out of the external case, mount it in your tower, and see if it's visible that way. Do NOT try this unless you know what you're doing. It's possible to really mess up your system. But if you've been in the case before and are comfortable with installing drives, this could be worth a shot.
Posted on Sep 05, 2007
Mac doesn't read the drive. Time Machine reads 'delayed' then 'failed' because it can't read drive. Won't backup. Drive doesn't show up on screen.
- Open the disk utility application found in the applications folder, then open the utilities folder
- See if it detects the LaCie drive by looking on the right hand side where it lists all the available drives including your optical drive
- If it is just greyed out you might only need to re-format the drive or possibly repair the disk.
- If it does not appear in this list the drive has most likely failed and is not economically repairable
May 17, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My WD External hard drive is no longer recognized by my Mac. It was fine when I went to bed. Showed no warning symptoms that I am aware of.
I would like to know the way the Drive is connected to MAC.
Have you connected it using USB or Firewire ?
If you have connected it using Firewire, Try connecting it using USB 2.0 Cable.
Let me know.
Regards,
Ron
Dec 10, 2010 | Western Digital 4TB My Book Studio II Hard...
Upload DV video camera to Mac.
Hi Dana
I would be inclined to suspect that the firewire on your Mac has gone bad - it does happen now and again.
Is it that the camera doesn't show up in iMovie or does it not even show on the desktop as an untitled drive?
I have an unknown brand HD Camera that only has USB and it will not show up on my Mac - but if I take the card out and put it into the card reader it shows up as a drive and the Video files are there to download.
Sep 03, 2009 | JVC Cybercam GR-DV2000 Mini DV Digital...
WD My Book Studio Ed. (Mac) - 2TB - stopped working for no reason
plug your drive in to your computer, right click
on my computer and bring up disk manager,
open disk manager and see if your wd drive
shows up. then reinitialize the drive and this
will hopefully solve your problem.
Aug 21, 2009 | Western Digital My Book Home Edition 500...
Mac External Connection
Easy, FireWire.
Connect the 2 with a firewire cable. If reading off the laptop, for example, reboot it & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The laptop should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Connecting another Mac to a laptop
Connect the 2 with a firewire cable. Reboot the Mac you want to read from & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The other Mac should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Firewire problem
this sounds like you could have blown the firewire port on the mac, this can happen if you plug in and out, even though it is supposed to be hot swappable. if nothing shows up on the firewire port but does show up on other ports on other computers then that could be the problem. its back to base with apple for a repair.
Apr 01, 2009 | Digidesign Digi 002 Rack FireWire Pro...
Today my firewire bus powered mac mini 320GB external hard drive (that i bought this year) stopped being powered by firewire alone and needed the USB plugging in as well to be recognised and used...the...
Hi-
Chances are these large memory hard drive should be plugin with a USB and adapter of its own since 320Gb is too big and needs power to be able to recognize. But if you find it defective you have a year warranty from the manufacturer, you can call them up for a replacement.
Hope this help. Thanks for using Fixya!
Jul 16, 2008 | Computers & Internet
MyBook's power light is blinking, but not showing up on my Mac's desktop
Data recovery usually will cost about 2000 - 3500. i may be able to help as long as the platters aren't physically damaged. Send me the drive at your cost. I will pull all data and return data on burned dvds I keep the drive. If i can't retrieve data then i will return drive to you at my cost. jprusso@yahoo.com
Jun 01, 2008 | Western Digital 320GB MyBook External USB...
Open Questions:
Fantom Drives 300 GB Hard Drive Logo
320 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
