Question about Minolta magicolor 2300W Laser Printer
2 multi color lines loud vibration noise
I purchased a used 2300 and when it prints, down the right hand side of the print are two multi color lines. I've taken numerous items out and wiped them down, but still I get those two lines. To make matters worse, after pulling out one of the rollers, there is now a loud horn like noise which I think might be caused by vibration on initial start and during printing. HELP
  • 20 Answers
If you have changed the OPC drum and cleaned the entire insides of the printer after taking out the toner cartidges and OPC drum.You need a tech to look at it. The fuser is probably messed up from loose toner.
Posted on Sep 05, 2007
SOURCE:
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
Color lines down sides
ITB Belt cleaning blade failure- new ITB required
Jan 22, 2014 | HP LaserJet 3700n Printer
If I print a large quantity in one print, the first two or three pages wil print fine then the rest will mess up. The left hand side of the page will mis-print and it squeals every so often. I just...
the drive gear assy. that moves the opc belt are broken.
honestly is time to get a new machine instead of spending a lot of money trying to fix this Lemon,sorry.,
Sep 10, 2010 | Brother MFC-9420CN All-In-One Laser...
Color line along side of copies; doesn't always print; error message keeps blinking (no manual),
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta magicolor 2400 Laser...
Samsung CLP300 cover pops open while printing
if you used a non samsung toner cartridge replace it with another of a different brand or a samsung one. when it pushes the cover open look to see which toner cartridge is pushed out and replace that one
Feb 24, 2009 | Samsung CLP 300 Laser Printer
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
Printer making funny noise and print is almost peeling off the page on the right side
Your problem is with the fixing film in the fuser assembly (HP Part #RM1-3044). The brown material you see is the plastic film ripping and peeling off of the hheating element.
Jan 23, 2007 | HP LaserJet 3050 All-In-One Printer
Minolta magicolor 2300W Laser Printer Logo
107 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
